The most... Different plane I've seen in a while
Old May 15th 06, 07:50 AM posted to rec.aviation.homebuilt
Default The most... Different plane I've seen in a while
I'm not even going to make a comment. Just - offered for your perusal
http://www.woopy-fly.com/
Old May 15th 06, 08:16 AM posted to rec.aviation.homebuilt
mmm, called woopy fly because a few minutes flying will creat a woppy in
your pants ?? Interesting but watch out for punctures, now if you can
fill with helium
Old May 15th 06, 09:46 PM posted to rec.aviation.homebuilt
("User" wrote)
fill with helium
If you're going to have a 5 gallon can of gasoline as a headrest, I say why
not fill the envelope with hydrogen, too?
Montblack
Old May 15th 06, 10:49 PM posted to rec.aviation.homebuilt
I seem to remember a Bede design of similar concept?
Leon McAtee
Old May 16th 06, 01:18 AM posted to rec.aviation.homebuilt
"Richard Riley" wrote in message
I open a page that has only a picture, and a little text. There are no
active links.
Does anyone else's show any other information?
Old May 16th 06, 02:09 AM posted to rec.aviation.homebuilt
"Morgans" wrote in message
active links.
I had the same result. Figured it was just me!
Peter
Old May 16th 06, 02:22 AM posted to rec.aviation.homebuilt
("Morgans" wrote)
active links.
When that happens to me, I switch from FFox to M$ IE. Sometimes that helps.
Links are on the left - section is yellow.
les textes ne sont qu'en français pour le moment
text only in french at the present - huh? :-)
News
info générale
woopykite
photos du Woopy motorisé
videos du Woopy motorisé
mise en oeuvre du woopy motorisé
aérodynamique
contact
Mont-blanc
Old May 16th 06, 02:38 AM posted to rec.aviation.homebuilt
"Montblack" wrote in message
("Morgans" wrote)
active links.
helps.
News
info générale
woopykite
aérodynamique
contact
Mont-blanc
OK, now I see. They are all accessed through "videos du Woopy motorisé"
Peter
Old May 16th 06, 04:30 AM posted to rec.aviation.homebuilt
Nope. Nothing like that on my screen. No links anywhere. I'm using IE,
but I have a lot of video playback and other features turned off. If that
is what it takes to view this stoopid site, I'll live with it! g
Old May 18th 06, 02:11 AM posted to rec.aviation.homebuilt
You're probably just as well off. It appears to just be a trike with a fat
wing--whether it is inflated or has full ribs is not obvious to me. Anyway,
the only real novelty is the cartoonishly plump appearance.
Peter
OK, I admit it, I am not a trike fan.
Passenger crash-lands plane after pilot suffers heart attack R.L. Piloting 7 May 7th 05 11:17 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
