Need help identifying a special tool
Old May 17th 06, 04:16 AM posted to rec.aviation.homebuilt
Default Need help identifying a special tool
My maintenance manual describes (what appears to be) a 90º gear drive
extension. I cannot identify it by part number, nor can I seem to locate a
source for purchase.
Details: http://www.turbinefun.com/SpecialTool.asp
Any help you could provide would be greatly appreciated.
Thanks for your help.
Larry
Old May 17th 06, 08:44 AM posted to rec.aviation.homebuilt
Larry
If you can get a torque wrench in where the 90º angle is you won't
need part 4. I have seen the tool to which you refer with a T handle
instead of a socket. Have you tried Sears? I don't recall where I saw it.
Dan, U.S. Air Force, retired
Old May 17th 06, 12:45 PM posted to rec.aviation.homebuilt
extension.
Uselessly, for you, I have a very similar thing in
my office here in (London UK). It is a 90 degree drive
but with a simple 'T' handle and not a square drive. There
is 'just as uselessly' no manufacturer's mark on it of any kind.
They do exist. Keep looking.
Check out you local professional tool store. Call you
friendly local Snap-on guy.
As mentioned already you may find a torque wrench
somewhere with a small enough head.
Old May 17th 06, 04:30 PM posted to rec.aviation.homebuilt
"Dan" wrote in message
news:vvAag.29365$fG3.15672@dukeread09...
a
Larry
I tried Sears, and will check with a different Snapon guy. The problem is
item 4 is in such a tight spot there's not enough room to swing a handle of
any kind.
Larry
Old May 17th 06, 04:46 PM posted to rec.aviation.homebuilt
extension.
Here are a couple:-
1/4, 3/8 only though. They /are hard/ to find.
http://www.aircraftspruce.com/pdf/catalog/Cat06540.pdf
http://www.aircraftspruce.com/catalo...in_ratchet.php
SPINNING RATCHET W/ 3/8" DRIVE 12-00742 | pdf $38.50
http://www.spectools.com/speccat.asp
More 1/4 drive
90 and 105 degree
bevel ger offset driver
SP 1002 Offset Bevel-Gear driver w/ratcheting handle
Spec Tools offers an extensive line of bevel gear drive tools based on
our
patented, award winning, Skewdriver ™ , offset screwdriver design.
Using the
rotary input action of a straight screwdriver or electric drive tool
through
hardened bevel gears to a magnetic 1/4"hex drive bit holder, these
tools get
you into those hard-to-reach areas where regular drivers and electric
drills
can't fit. Replaces awkward S-bend offsets, finger ratchets, stubby
screwdrivers
and cumbersome angle drills to speed work time, improve efficiency and
solve those
impossible access problems.
http://www.popularmechanics.com/home...s/1274141.html
## Twist handle to turn. No drive socket though.
The Quick Twist is available in 1/4-in. and 3/8-in. drives and costs
about $75. To find a distributor, contact
Midland Designs Inc., 210-347 Leon Ave., Kelowna,
British Columbia, Canada V1Y 8C7; 250-763-4442;
www.quicktwist.ca.--Roy Berendsohn
a
Larry
any kind.
Larry
Sounds like a job for a "crowfoot"?
Richard
Old May 18th 06, 04:28 AM posted to rec.aviation.homebuilt
I think a "Dickfore" wrench will work for this nicely.
locate
a
Larry
it.
handle of
any kind.
Larry
Richard
Help with Identifying Special Instrument Herbert Paulis Piloting 3 June 16th 05 04:36 PM
Special EWO School OXMORON1 Military Aviation 0 September 14th 04 10:50 PM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 05:09 AM
