82 UL Fuel
Old May 24th 06, 01:49 PM posted to rec.aviation.homebuilt
Default 82 UL Fuel
82UL was developed several years ago, to be easily produced from
automotive fuel. Instead of being produce by only one or two
manufacturers as 100LL is, 82UL could be made by any oil company. This
should make it cheaper to produce. 82UL is NOT a replacement for 100LL.
It is my understanding that about 30% of the general aviation fleet
requires 100LL to prevent detonation, but the other 70% can use 82UL.
With the cost of fuel these days, if 82UL is significantly cheaper than
100LL, it's availability might save general aviation.
With the new various laws requiring ethanol in automotive fuel, it seems
it would be more important than ever that 82UL be produced for the
aviation market.
Yet after all these years 82UL has yet to show up anywhere. What does it
take to get this fuel produced and available to aviators? Does it have
to come from the demand side, by making pilots aware of it's existence,
so they can start to ask for it? Why isn't EAA doing more to see that
this fuel gets produced and made available?
Old May 24th 06, 02:40 PM posted to rec.aviation.homebuilt
Default 82 UL Fuel
On Wed, 24 May 2006 12:49:05 GMT, floater
that question is easy to answer.
since you appreciate the need you need to build a refinery to produce
it.
be the first and you'll be able to sell it to the other EAA members.
Stealth Pilot
Old May 24th 06, 02:57 PM posted to rec.aviation.homebuilt
Default 82 UL Fuel
it.
Stealth Pilot
"82UL was developed several years ago, to be easily produced from
should make it cheaper to produce."
Old May 24th 06, 10:09 PM posted to rec.aviation.homebuilt
Default 82 UL Fuel
"floater" wrote in message
news:lDZcg.8066$Ar6.1873@trnddc02...
it.
Stealth Pilot
There was a discussion on this NG a week or two ago which suggested that, if
you removed the alcohol from typical blended automotive fuel, you would have
approximately 82 octane unleaded gasoline. If that assertion is true, then
all of the refineries which produce ethanol blended gasoline are already
producing 82UL in ample quantity. However, they may not currently be
loading it onto tankers and delivering it in that form.
As I say, this is outside my areas of expertise. But some of you probably
do know.
Peter
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
