Torque Value for Mounting an O-320 wide deck.
Old May 27th 06, 08:40 PM posted to rec.aviation.homebuilt
Default Torque Value for Mounting an O-320 wide deck.
Dear Group,
I am in the process of building my cowling and have the engine up on the
mount. What I need to know is what is the amount of torque on the engine
mount bolts? I have rebuild manuals, parts manuals and the owners manual
but can't find a torque for tightening. The engine is a dynafocal mount
O-320-E2D which is a wide deck. Also after the bolts are torqued, will I be
able to remove the engine and use the same rubber mounts upon final
installation? Or simply tell me where I could find that information.
Thanks.
John "Ebby" Ebensperger
Hatz Classic s/n37
Camden, NY
Old May 30th 06, 02:36 AM posted to rec.aviation.homebuilt
You can reuse the rubber mounts, no problem.
I would torque the mount bolts using a standard torque for that size bolt,
whatever it is. The Lycoming installation drawing for that engine should be
of great help as well.
SHR
"Ebby" wrote in message
Dear Group,
be
Thanks.
Hatz Classic s/n37
Camden, NY
Old May 31st 06, 02:00 AM posted to rec.aviation.homebuilt
SHR
That torque value is for pulling dowwn hard on something like
solid steel(?)
You torque that far you'll be metal to metal and ruin the pads
at the same time...
come on, guys, this was discussed before, wasn't it?
Richard
Continental A-75 hub torque SteveR Home Built 8 July 21st 05 10:49 PM
Proper Torque for Fuel Fittings Steve Waltner Home Built 10 February 20th 05 01:46 AM
Drum dia and torque Bob Johnson Soaring 15 November 22nd 04 08:37 PM
Deck height Sean Trost Home Built 5 July 16th 04 04:46 AM
The "Gipper" is ready! Phineas Pinkham Naval Aviation 0 July 8th 03 11:57 PM
