Hourmeter Checkout
Old May 28th 06, 04:36 PM posted to rec.aviation.homebuilt
Default Hourmeter Checkout
After my original stopped working, I orderd a Westach hourmeter from A.S.
Supply.
It does not work and before I send it back, thought I might check my
troubleshootinmg logic G as it seems unlikely I'd get a bad meter.
In plane: confirmed ground and hot leads installed properly on meter
backside and actually had a ground and a +. After 1.3 hours flight, reading
is zero!
In hanger: disconnected planes leads from meter and connected a ground and a
+ from an external battery. After 20 minutes, no reading (still zero).
What am I missing?
Thanks, Dick
Old May 28th 06, 08:27 PM posted to rec.aviation.homebuilt
Supply.
is zero!
What am I missing?
Thanks, Dick
Possibilities:
1) it's an AC powered meter
2) it counts in units of 'many' hours -- maybe 100-hour units
3) it's mechanically bound up, and just needs a little 'impact engineering'
to get it started.
4) there is a 'lock', mentioned in the directions, and you didn't read 'em.
5) "It's dead, Jim".
check the specs,
check the installation directions,
call tech-support
Need Virus/Sinus Checkout Mark Lenox Soaring 6 January 20th 06 03:53 AM
Checkout in a G1000 C182 Greg Esres Piloting 22 April 13th 05 10:04 PM
Another taildragger checkout question Bob Martin Piloting 3 May 17th 04 02:31 AM
