Jim Weir, Yagi Antenna
Old May 29th 06, 12:10 AM posted to rec.aviation.homebuilt
Default Jim Weir, Yagi Antenna
Hello Jim,
this is an eMail from Germany, from a non-American reader of kitplanes.
My name is Bernie and I'm aeronautical engineer with almost no clue
about high frequency electronic things like antennas.
So I have a few questions regarding your article:
- what is a #10 copper wire (in diameter or in cross seqional aerea) ?
- If I nestle a 1/2 inch wide copper tape around a 1/4 inch diameter
dowel the tape does not build a closes tube. Is that right?
- If I understand your figure 1 "the coaxial balun assembly" right I
see no connection from the inner coaxial conductor to any element of
the antenna. Is that right?
I would be very glad if you could halp me to get the antenna right.
Thank you very much in advance.
Kind regards
Bernie
Dr.-Ing. Bernhard Carl
Dietramszellerstraße 21
D-83624 Otterfing
Germany
Tel 08024 - 99 13 88
Fax 08024 - 99 13 90
eMail:
Old May 29th 06, 12:44 AM posted to rec.aviation.homebuilt
In article .com,
Hello Jim,
"#10" refers to a standard known as "American Wire Gauge". Google for
"wire gauge table" and you should turn up the statistics you need.
Cross-section is very close to 10,000 'circular mils', so the wire
diameter is 0.10 inches, within 2%.
Kind regards
Bernie
D-83624 Otterfing
Germany
eMail:
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
Jim Weir - Rubber 'Baby Belly Baluns Ron Wanttaja Home Built 6 April 5th 05 01:57 AM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Marker Beacon Antenna - Paging Jim Weir. Bart D. Hull Home Built 1 November 27th 03 10:31 PM
