Carrier Aircraft Catapault Hold-Back Bar / Mechanism ?
Old June 8th 06, 05:47 PM posted to rec.aviation.military.naval
Default Carrier Aircraft Catapault Hold-Back Bar / Mechanism ?
Hello:
Retired Engineer.
Have always been interested in carrier catapaults.
I have tried to find a good, relatively technical, description on the web
with some diagrams or pix of the aircraft hold-back mechanism that's used
immediately prior to launch that restrains the plane.
Doubt that they still use breakable (frangible) type of bolts, but perhaps ?
Do they ?
Anyone know of any good sources to learn more about how this is actually
done, and what
these mechanisms look like ?
B.
Old June 8th 06, 06:07 PM posted to rec.aviation.military.naval
"Robert11" wrote in message
Hello:
Retired Engineer.
Do they ?
The 'breakable' holdback certainly is still in use today. It's not a bolt,
but looks more like a 'double mushroom' where the center has been machined
down to certain specs. It is designed to separate at a predetermined stress
point.
Old June 8th 06, 10:43 PM posted to rec.aviation.military.naval
Robert11 wrote:
Hello:
Retired Engineer.
Do they ?
done, and what
B.
The tension bar contains a breakable link that looks like a piece of
2-1'2" diameter steel shafting about 3" long was chucked in a lathe and
parted in the middle except for the last 1/2" to 3/4". They are
color-coded by aircraft type.
http://www.tpub.com/content/aviation...s/14014_86.htm
(figure 4-16)
http://www.tpub.com/content/aviation...s/14018_27.htm
Rick
Old June 9th 06, 12:35 AM posted to rec.aviation.military.naval
Do they ?
done, and what
I have one in front of me, from my first S-3 launch. My half (other
half stays in the shuttle until the deck crew discards it) looks like
half of a palm-sized purple yo-yo. Each a/c type used a different
color as each a/c had a slightly different holdback fitting.
v/r
Gordon
Old June 9th 06, 12:49 AM posted to rec.aviation.military.naval
"Gordon" wrote in message
ps.com...
perhaps ?
Do they ?
actually
done, and what
Agreed. And they are NOT interchangeable deliberately so Sailors don't screw
up and put the wrong one in.
If the wrong holdback fitting *could* be installed (with the associated
incorrect release pressure), the results could be disastrous. The cat could
either release without enough steam pressure to get the aircraft fully
airborne or the 'live cat' could just sit there without enough pressure to
break the holdback (instead of actually launching the aircraft) until the
steam pressure is bled off (aborting the cat shot).
Old June 9th 06, 01:07 AM posted to rec.aviation.military.naval
What?! Are you suggesting squids occasionally eff-up?
ok, ok, I'll agree - if we CAN screw something up, at some point, some
kid will. I watched an A-3 take off once, followed by an A-7...
Problem? The cat was not reset and the Corsair was tossed off the boat
"with alacrity", causing noticible damage (belly pan detached during
the blistering fast takeoff run among other problems). Whenever
someone makes a device idiot proof, along come better idiots!
v/r
Gordon
Old June 9th 06, 12:41 PM posted to rec.aviation.military.naval
Default From OP: Carrier Aircraft Catapault Hold-Back Bar / Mechanism ?
Hi,
Thanks for info.
a. What happens to the piece of the breakable link that is part of the bar
that stays with the plane ?
Does it go flying with the plane to be removed later, or... ?
b. Any info on the newer, I think, types of hold-back mechanism that do not
utilize the breakable bar, but apparently use some type of captivated
spring/cam mechanism as part of the bar (permanently) ?
Thanks again,
Bob
Hello:
Retired Engineer.
Do they ?
done, and what
B.
Old June 9th 06, 04:38 PM posted to rec.aviation.military.naval
news
Hi,
Thanks for info.
bar
Yes, and it is later removed by the Plane Captain as part of the "Turn
Around Inspection" after landing.
not
Not part of the Steam Catapult system. The holdback may change with the next
generation of launch systems.
Old June 24th 06, 05:40 PM posted to rec.aviation.military.naval
news
Hi,
not utilize the breakable bar, but apparently use some type of captivated
Thanks again,
Bob
Yes, they're called RRHAs (Repeatable Releasable Holdback Assembly). They're
a one-piece bar that fits into the back of the (A/C's) strut and on the
strut there are two metal plates that sandwich the holdback bar. In order to
launch, the bar must have enough force applied to it for it to slide past
the metal plates/springs. It's basically like some cabinet doors that have
the little pokey thing that have to slide inbetween two springs in order to
open... they come in different shapes and sizes for different airplanes so
they don't get one with the wrong-sized "fist". Since nothing breaks during
launch, they can be reused. They just have to be inspected every once in a
while to make sure there's no stresses inside the bar that might make it
break, and also to make sure the fist hasn't worn down too much.
Jason
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
