Garmin gpsmap 96 and onlinecontest?
Old June 9th 06, 06:25 PM posted to rec.aviation.soaring
Default Garmin gpsmap 96 and onlinecontest?
Is it possible to use this device with some of approved software which
generate igc files (g7towin for example) for online contest?
I mean, is it possible to use GPS device without barrometric altimeter
instead of approved GNSS flight logger? I couldn't find the answer on the
OLC web pages...
THNX!
Old June 9th 06, 08:04 PM posted to rec.aviation.soaring
I'm not specifically familiar with your Garmin, but I'm doing this with
an old Garmin II (a cheap, basic model 3-4 years old) and an iPAQ
running GPS_LOG WinCE, but there were some cabling issues to address.
I needed:
a) Garmin GPS to serial cable (Amazon)
b) Serial male-female gender adapter or "sex changer" (Radio
Shack)
c) Null modem (Radio Shack)
d) Serial to iPAQ cable (eBay)
All together, these cost about $75. The elements are connected in this
order from the GPS to the iPAQ, which is stowed behind my seat. (I
don't look at the iPAQ in flight; for me it is a simple logging device
which takes the GPS data and converts it into an .icg file.)
The program and more information are available at
http://www.soaringpilotsoftware.com/GPS_LOGpage.htm
Old June 9th 06, 08:48 PM posted to rec.aviation.soaring
OLC web pages...
THNX!
The short answer is "yes." The rules are under the validation
section, he
http://www2.onlinecontest.org/validate.php
A gpsmap 96 downloaded with G72Win will be fine; just be sure you're
using a recent version of G72Win.
BTW, I should have clarified that the "OLC Classic" requires an
IGC-Approved logger, but as long as you just want to get points in the
general contest, a Garmin is fine.
Old June 10th 06, 12:46 AM posted to rec.aviation.soaring
OLC web pages...
THNX!
section, he
http://www.ssa.org/members/contestreports/OLC.htm
"For the OLC-league and for the FAI-OLC (OLC triangle flights according
to FAI rules) only IGC approved recorders are allowed."
OLC Classic continues to accept non-approved recorders that return a
valid file.
Jack
Garmin 96 and onlinecontest? DBn Soaring 0 June 9th 06 06:22 PM
