Cessna TR182 IFR configurations/power settings
Old June 12th 06, 04:40 PM posted to rec.aviation.piloting
Default Cessna TR182 IFR configurations/power settings
I am trying to determine the best IFR configurations/power settings for
my Cessna TR182. For example:
APPROACH LEVEL GEAR UP: MP 17 in, RPM 2300, IAS 100, VS 0, Mix Rich,
Carb Heat OFF, Flaps UP, Cowl flaps closed
seems to work but I would like to hear from other 182 pilots:
What approach level config/power setting do you use? Should Carb Heat
be ON so monitoring carb temp not so important on final approach
course? Do you put gear down before or at (as I was taught) FAF/point?
Do you use 10 degrees of flaps in this configuration? If you put gear
down at FAF, what other adjustments are needed to get VS = -500 at 100
KIAS? (I have to put Carb Heat ON and/or pull power back a bit to 16
in)
thanks
Greg
Old June 12th 06, 06:41 PM posted to rec.aviation.piloting
"Greg" wrote in message
in)
thanks
Greg
On a Turbo 182 RG I leave everything clean untill the FAF "carb heat on,
gear down or GUMPS" fly the approach as normal once runway environment is in
site then I start adding flaps etc.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 07:51 PM
Cessna 404 Cruise settings Katia General Aviation 0 December 19th 03 06:04 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
