O/A welding question: tip size
Old June 14th 06, 12:10 PM posted to rec.aviation.homebuilt
Default O/A welding question: tip size
I'm having a welding problem. I'm using an OxyAcy rig. I'm
running 2 psi for each gas thru a .025 diameter tip. I find that in
order to weld join two pieces of .035 tubing with this tip, I must
adjust the flame until it's no larger than 3/16" long. Otherwise
I'm heating up too much of an area and burning away the outer sleeve
(in the case of a splice using an inner sleeve). A flame that small is
very difficult to adjust.
I'm puzzled because the charts I'm looking at show a tip of this
size is appropriate for this size work.
Can you suggest what might be my problem? - Regards, Mike
Old June 14th 06, 01:11 PM posted to rec.aviation.homebuilt
"mhorowit" wrote in message
too much oxygen
Old June 14th 06, 01:34 PM posted to rec.aviation.homebuilt
Morgans wrote:
too much oxygen
Hello Jim - If I simply reduce the O2 at the handle, I'll get a
carburizing flame, right? I need a neutralized flame - MIke
Old June 14th 06, 02:15 PM posted to rec.aviation.homebuilt
Morgans wrote:
too much oxygen
This group has had many good descriptions of how to get the proper flame;
you might want to look it up. Yes, it should be neutral.
To give the short version, the inner flame should have a soft, feathered
edge, not a sharp, defined edge, and it should be a "quiet" flame.
If it makes soot, there is not enough O. If it burns the metal, (sparkles)
there is too much O.
You might need to move faster, take the flame further from the work, get the
filler metal in there faster, so it will get to the business of melting, or
even take the flame away for a second, every few seconds.
Old June 14th 06, 03:48 PM posted to rec.aviation.homebuilt
Morgans wrote:
too much oxygen
Jim - I know how to make a neutral flame. I was just trying to figure
how reducing O2 would help since if that's all I did, the flame would
no longer be neutral. So I guess I need to follow your last para.
Thanks, Mike
Old June 14th 06, 06:19 PM posted to rec.aviation.homebuilt
| ups.com...
| Morgans wrote:
| too much oxygen
| Jim in NC
flame;
feathered
(sparkles)
get the
melting, or
| Jim in NC
| Thanks, Mike
Just curious! Are you using the J-57 aircraft torch?
Jarhead
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= East/West-Coast Server Farms - Total Privacy via Encryption =---
Old June 14th 06, 07:08 PM posted to rec.aviation.homebuilt
Jarhead
Nope - an old lightweight Smith handle with MW 100 series tips.
I've discovered that the only standard description across tips is the
orifice opening, so that's why I'm not using tip names. - MIke
Old June 14th 06, 10:03 PM posted to rec.aviation.homebuilt
mhorowit wrote:
Jarhead
Might I ask if there is a reason for holding 2 psi?
That seems a tad low...
Old June 14th 06, 10:15 PM posted to rec.aviation.homebuilt
I was wondering the same thing. I usually go with around 32 Oxy, and 7
Acet. I am surprised he could get a neutral flame with those settings, but
he claims to know what a neutral flame is, and that he is getting it. I
wonder if his gauges are off...
Old June 14th 06, 10:52 PM posted to rec.aviation.homebuilt
Heat needs to be mostly directed towards the inner sleeve and away from the
easy to burn exposed edge. Using a larger diameter welding rod to shield the
exposed edge can help. But it sounds like, in spite of what your chart says,
you need to use a smaller tip. Just be sure you are getting enough of a
puddle on the sleeve as you turn down the heat.
Geoff
Welding question - Michael Horowitz Restoration 11 September 7th 06 04:52 PM
Welding question: 43-13-1B, Fig.4-43 Mike Restoration 0 May 15th 06 03:36 PM
Aluminum welding Ernest Christley Home Built 5 April 24th 06 12:47 PM
Welding question Mike Restoration 4 February 20th 06 03:23 PM
Welding question Michael Horowitz Home Built 1 October 13th 05 10:53 PM
