Cherokee fuel sending units
Old June 24th 06, 01:53 AM posted to rec.aviation.owning
Default Cherokee fuel sending units
I have finally had enough of the bad sending unit on the right tank.
Since I want the beast in and out quickly, I figured I would get an
exchange unit from Airparts of Lock Haven. $500 core charge? Yikes! I
guess they REALLY want that core back!!! I believe the "stock" sending
units/gauges on a 74 Cherokee were Stewart Warner. I believe they made a
replacement Rochester combo and they are not interchangeable. Is this
correct?
I have had these pups (fuel tanks) out in 1999 to change the sending
unit gaskets, replace the main fuel lines, and replace the overflow
hoses. I replaced the tank screws with the proper structural stainless
screws. Can I reuse them? I do not recall anything saying they were
"one-time".
Towing Roger Fowler Soaring 6 August 11th 05 05:25 AM
Most experienced CFI runs out of gas Robert M. Gary Piloting 54 November 19th 04 02:24 AM
CHEROKEE NATIONAL FLY-IN - MORE INFORMATION Don Piloting 0 June 16th 04 06:15 AM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 07:13 PM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
