Problem with auto alternators
Old July 24th 06, 05:21 AM posted to rec.aviation.homebuilt
abripl[_1_]
Default Problem with auto alternators
One known problem is that aircraft engines turn CCW looking at the prop
but auto alternators have cooling fins optimized for CW. But thats not
apparently as much a problem as the pulley nut potentially comming
loose. For CW rotation the engine torque will tend to tighten the
pulley nut but for CCW it will tend to loosen it. It happened to me
today )on the ground) after 60 hours of use and the alternator was not
charging just spinning the pulley. Make sure you check your pulley nut
tightness ocassionally if you are using an auto alternator.
Old July 24th 06, 05:44 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On 23 Jul 2006 21:21:19 -0700, "abripl"
Are you telling me that all the aircraft versions of alternators have
left hand threads? Or even that alternators on engines that run
"backwards" or have the alternator on the back of the engine(like on a
Renault R12) have left hand threaded rotors?
I'm afraid I'd have to dissagree. Not ALL do. Perhaps SOME.
On counter-rotating marine engines, both alternators are the same.
Posted via a free Usenet account from http://www.teranews.com
Old July 24th 06, 07:29 PM posted to rec.aviation.homebuilt
They're all right-hand thread, even when used on a Lycoming and
turning "backwards." The fan has straight fins rather than the angled
fins found on some auto alternators.
I ran an alternator backwards on my inboard boat for years,
since there was no room alongside the engine for it and it had to go
out front and sit backwards and therefore turn the "wrong" way. The
thread never came loose, and the fan had straight fins that I got off
some alternator in the junkyard. Some cars had them that way.
Dan
Old July 24th 06, 10:42 PM posted to rec.aviation.homebuilt
jerry wass
Corvairs do--both the old generators and the newer alternators. some
loc-tite goes a Loong way in these situations..Jerry
Old July 25th 06, 06:43 PM posted to rec.aviation.homebuilt
On Mon, 24 Jul 2006 21:42:43 GMT, jerry wass
Corvair has left hand thread on alternator????? None that I've seen,
and the manual does not mention it - and the rotor is the same as any
other Delcotron.
Old July 26th 06, 03:46 AM posted to rec.aviation.homebuilt
Peter Dohm
clare at snyder.on.ca wrote in message
other Delcotron.
I really doubt that there were any left hand threads on small alternators,
but there were a number of auto engines that rotated in the opposite
direction. IIRC rear drive Chryslers used to rotate backward of GM, and I
believe that Honda currently rotates the reverse of most other front drives
due to the reversed position of the engine and drive train.
I hope this helps. It should at least net an appropriate fan.
Peter
Old July 26th 06, 10:50 AM posted to rec.aviation.homebuilt
JP[_1_]
"Peter Dohm" wrote in
t...
drives
Majority of the world's automotive engines rotate clockwise then viewed from
the accessory end. Chrysler and GM engines (small and big blocks) as well as
AMC, Ford etc. do rotate the same direction. In fact I don't know any auto
engines running counterclockwise, but that doesn't mean they don't exist.
JP
Old July 26th 06, 04:58 PM posted to rec.aviation.homebuilt
On installations with rear mount alternators like Cont io/o 470s
in Skylanes, and such, the alternator turns backwards. There
is a special pulley with the fan fins in the opposite direction.
If you use automotive stuff, you will find that the fins are
backwards and the centerline of the belt is about 1/8" farther
from the alternator case than it is on the aircraft one.
Needless to say, the alternator could care less which
direction it is turning.
Bill Hale A&P
Old July 26th 06, 09:53 PM posted to rec.aviation.homebuilt
karl gruber[_1_]
I had a ski buddy in the 50's that had a 2-cycle Saab. He liked to park
uphill and coast backward in a forward gear and pop the clutch. Then he had
several reverse gears and one forward.
It reminds me of my favorite episode on "Candid Camera." They had a
beautiful buxom blonde trying to park a big car in a supermarket parking
lot. She was having problems and would ask men to help her park. Well, these
guys would swagger up to help the poor miss out, except, the crew had
reversed the steering somehow......so left was right. It was hilarious.
Karl
"Curator" N185KG
" wrote in message
Bill Hale A&P
Auto Tow Information Steve Leonard Soaring 13 August 23rd 05 04:19 AM
Shutting down alternators before engine shutdown Ali Ghorashi Piloting 4 October 29th 04 11:48 PM
vortex ring state at any point during an auto?? Greg Johnson Rotorcraft 18 August 30th 04 09:12 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
