Veedubber's Tech-Line Coatings
Old July 26th 06, 06:45 AM posted to rec.aviation.homebuilt
Ernest Christley
Default Veedubber's Tech-Line Coatings
Mr. Hoover, I've been pondering the thermal barrier and thermal
dispersants that you've advocated several times. Ponder with me for a
moment if you will.
I've got an experimental engine, with an experimental cooling setup. Do
know for guaranteed that the cooling will be sufficient, so I'll be
keeping a close eye on the water and oil temperatures. But the coatings
will cause more heat to be dumped into both. How would a typical
homebuilder know the difference between elevated temps due to a more
efficient heat transfer and inadequate cooling?
Then there is the issue of what the redline temperatures are set for.
In the rotary, it is for the main bearings. Would the barriers and
dispersants change the thermal characteristics in such a way that the
temps readings taking in the normal places look adequate, but in reality
critical parts are being fried?
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
spinner paint scheme Dick Home Built 3 January 27th 05 10:58 PM
Space Elevator Big John Home Built 111 July 21st 04 05:31 PM
striped spinner Pianome Home Built 1 July 4th 04 10:56 PM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 10:27 PM
September issue of Afterburner now on line Otis Willie Military Aviation 0 September 9th 03 10:13 PM
