master warning
Old July 27th 06, 04:50 PM posted to rec.aviation.simulators
Kevin
Default master warning
Hello all,
As I begin to figure out how to fly the A321 jet, I have encountered a
significant problem. As I reach 30,000 feet, my master warning sign
comes on. I have low oil pressure and my N1 remains at 92%. At the
same time, my airspeed drops to ~110. I believe it has something to do
with the cowlflaps, but I am not sure. If it is indeed thecowl flaps,
how do I adjust them in x-plane. If not, any suggestions?
Old July 27th 06, 08:28 PM posted to rec.aviation.simulators
RobertVA
Kevin wrote:
Hello all,
Using the altitude hold on the autopilot? If so what is the climb rate
set to? What is your fuel level? Did you have the throttles set for
maximum all the way to 30,000?
An aircraft can't maintain the same indicated airspeed with a high climb
rate at high altitudes. It's necessary to reduce the climb rate
significantly as you approach cruise altitude.
Many aircraft can't reach their normal cruise altitude immediately after
takeoff with a full fuel load. If the flight duration requires that much
fuel the plane has to cruise at a lower altitude for a while until fuel
consumption reduces its gross weight. If the autopilot increases the
angle of attack enough while attempting to climb with too much weight
there MIGHT be some effect on airflow into the engines.
There are sometimes limitations on the time jet and other turbine
engines should be operated at maximum throttle settings. The operating
procedures might call for some large fraction of maximum throttle after
the first few minutes in flight. There may be some simulator aircraft
models that imitate the malfunctions that could result from prolonged
operation at maximum throttle.
Master Jet Base MICHAEL OLEARY Naval Aviation 24 April 22nd 05 08:00 AM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 09:40 PM
S-TEC 60-2 audio warning Julian Scarfe Owning 7 March 1st 04 09:11 PM
Plane with no stall warning device? Roy Smith General Aviation 23 February 17th 04 04:23 AM
Need G-103 Acro Master Cylinder Ray Lovinggood Soaring 5 September 30th 03 04:39 AM
