Side stick plans
Old August 8th 06, 10:19 PM posted to rec.aviation.homebuilt
Lou
Default Side stick plans
Does anyone know where I can get plans for building my control stick on
the side instead of in between my legs. My plans call for in between
the legs and I would like to look at other options. The problem is I
can buy a full set of plans but which one? Anyone have an idea?
Lou
Old August 8th 06, 10:24 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
"Lou" wrote in message
Lou
What airplane are you building? It will make a difference.
Old August 8th 06, 10:54 PM posted to rec.aviation.homebuilt
Lou
http://www.homebuilt.org/kits/littner/champion.html
Old August 9th 06, 02:08 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Nice looking airplane Lou. But a quick Google search doesn't come up with
much info on it. Is there a builder's group for it? That might be your best
place to look.
Old August 9th 06, 04:12 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
"TigerPilot" wrote in message
Lou
The Lancair IV has a side stick, see if you can find someone who builds
one or has one built and look at it.
The Cozy MK IV is a plan built and has side sticks. AS&S sells the
plans.
The Zenith 601 series is a side stick that is mounted between the seats. You
might go over to zenithair.com to see if that might work for you.
Old August 9th 06, 04:21 PM posted to rec.aviation.homebuilt
john smith
Does not the design of the sidestick depend on the aircraft it will be
used in?
Old August 9th 06, 11:02 PM posted to rec.aviation.homebuilt
Lou
John, if i understood your question then yes, but I'm looking for ideas
to adapt to my plane.
I could buy the Cozy plans but I'm looking to not spend a bunch of
money for the whole set of plans just to get this part that may or may
not work.
Lou
Old August 10th 06, 02:03 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
not work.
Lou
And you may not be able to simply adapt plans from one aircraft to another.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
slow roll in a super decathlon Nobody Aerobatics 4 August 24th 05 02:36 AM
PLANS BEACH BOY ST-II ULTRALIGHT tony Home Built 0 October 10th 03 07:50 AM
Here's a silly question regarding plans David Hill Home Built 21 October 8th 03 04:17 AM
