Airmap 2000c: Towers, Making a copy of the SD, Taxi-ways
Old August 20th 06, 02:00 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.marketplace,rec.aviation.products
John Mireley
Default Airmap 2000c: Towers, Making a copy of the SD, Taxi-ways
I've got several questions about the 2000c. My attempt to email Lowrance
has resulted in no information so far. They did say they got the request.
I've been unable to see towers displayed on the map pages as shown in
the manual. I am unable to see taxiways. I've not found a description of
this anywhere. I assume that is what the Taxiways file is and it is only
for the larger airports.
I've not flown with the 2000c yet.
I tried copying the files from the OEM SD to a new 1 GB SD from CompUSA.
The files appear in the 'Browse Files' menu just as they do on the OEM
SD. However , none of the data is available.
The 2000c was purchased 8/15.
The contents of the OEM SD copy
06/28/2006 02:09 AM 314,085,653 Terrain_Americas.at5
06/28/2006 02:09 AM 51,092,233 International Map.lcm
06/28/2006 02:09 AM 20,555,242 JepAmr0706.at5
06/28/2006 02:09 AM 4,382,606 Taxiways_v1_0.at5
4 File(s) 390,115,734 bytes
0 Dir(s) 625,131,520 bytes free
0 Dir(s) 121,815,040 bytes free
Old August 20th 06, 03:20 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.marketplace,rec.aviation.products
Jay Honeck
You don't mention whether you've explored the Lowrance website. There
is a wealth of knowledge (and downloads) there.
It took Lowrance a good week to respond to my inquiry.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 20th 06, 03:28 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.marketplace,rec.aviation.products
Thomas Borchert
John,
the manual.
Hmm. Are obstacles activated in the "Map Categories Drawn..." menu? Are you looking at the US or
outside?
Yes, only the largest. Look at their website at
http://www.lowrance.com/Aviation/tax...surveystat.gif for a directory. Try scrolling and zooming in
on JFK, you'll see something.
Yep, that's called copy protection. The files only work on that one SD card they have been activated
with. It still makes sense to back them up to the PC in case you delete them accidentally.
Check the version of your unit software against the updates available at Lowrance.com.
That's the terrain data (duh) for the Americas. There's one available for Europe, too.
That's the background map (major roads, lakes, rivers, big cities et cetera) for outside the US.
Jeppesen data for the Americas. This one you can update via download and "activation".
Taxiway maps. There should be a new one available every now and then for free download, with updated
maps and new airports.
Thomas Borchert (EDDH)
Old August 20th 06, 03:52 PM posted to rec.aviation.piloting
Edwin Johnson
They suggested I call them, but I was able to come up with the answer
without that.
Full map or compass overlay in the Aviation map. You will not see the towers
in that mode until you get the range down to a certain amount, say 10 miles
or less or something like that. As you increase the range, the lower towers
disappear, leaving only the very tall towers, and finally no towers. Guess
their reasoning is that if you are using a large range you are high and no
problem with obstructions.
That's the file and if you look on the website, www.lowrance.com , you will
find they have a file you can download (it's the same one in your present
unit, I'm sure) and it contains the larger airports, part of a gov plan. At
this point that plan has 80 airports. There is a map of the US showing the
airports included in that gov plan. To test, choose a large airport and
decrease the range and you will see the entire taxiplan, with labels.
I don't know about all of the files, but I _do_ know that the Jeppesen
database and any files you create with Map Create are assigned to the SD
serial/id number of that card. You can't copy the Jeppesen database to
another card and have it work. This is stated in the manual. The only thing
you can do is use the download facilities and download a new database for
$35. When you do, you must download a Jepp file/program which 'unlocks' the
encrypted file and assigns it to the SD card you have in the reader on your
computer, which you will then place in the GPS unit. All of this is
explained in detail on the website. There is an option to purchase a larger
card with the Jeppesen database on it, rather than download.
....Edwin
__________________________________________________ __________
"Once you have flown, you will walk the earth with your eyes
turned skyward, for there you have been, there you long to
return."-da Vinci http://bellsouthpwp2.net/e/d/edwinljohnson
Lowrance AirMap 2000c update Stephen Farris Owning 7 June 24th 06 06:46 PM
Lowrance AirMap 2000c update FlyWithTwo Home Built 2 June 8th 06 11:00 AM
Lowrance AirMap 2000c update Stephen Farris Instrument Flight Rules 0 June 4th 06 03:24 AM
Garmin 296 or Airmap 2000C ? [email protected] Piloting 19 September 26th 05 11:03 PM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 09:32 PM
