IAP through class G
Old August 12th 04, 02:38 AM
Gary Drescher
Default IAP through class G
Why do some airports with an instrument approach (e.g. HIE) lack a surface
Class E to protect the approach? HIE LOC 10 has Class G below 700' AGL, but
the MDA is well below that height. A plane can legally fly VFR just below a
700' ceiling along the final approach course, with no way for it to see and
avoid an approaching IFR plane, or vice versa.
--Gary
Old August 12th 04, 03:09 AM
Roy Smith
In article p_ySc.132920$eM2.100919@attbi_s51,
It's a regulatory thing. In order to have controlled airspace to the
surface (what's known as a "surface area"), you need to have approved
weather reporting. Interestingly enough, HIE has an ASOS, which I
thought would have counted as "approved weather reporting", but maybe
not?
Yup. Big sky, small plane. If that sort of stuff scares you, stick to
places with surface areas. Of course, there's nothing to prevent
somebody from flying IMC illegally without a clearance, even when there
is a surface area.
Steven P. McNicoll
news_ySc.132920$eM2.100919@attbi_s51...
surface Class E to protect the approach? HIE LOC 10 has Class G
below 700' AGL, but the MDA is well below that height. A plane can
legally fly VFR just below a 700' ceiling along the final approach
course, with no way for it to see and avoid an approaching IFR plane,
or vice versa.
Controlled airspace at the surface requires surface weather observations and
radio communications capability with ATC down to the runway surface. If you
do not have both of those an airport with an SIAP will have Class G airspace
from the surface to 700' AGL.
Old August 12th 04, 03:43 AM
Bob Gardner
That's just one of the gotchas in instrument flying...if you shoot an
approach into a field where controlled airspace stops at 700' agl you have
to be extra alert just in case. Odds are against anyone doing pattern work
in such conditions, but Murphy's Law always applies.
Bob Gardner
but
a
and
--Gary
Old August 12th 04, 04:03 AM
Barry
a surface Class E to protect the approach?
In fact this is the case for the great majority of non-towered airports.
Old August 12th 04, 01:32 PM
Gary Drescher
hlink.net...
and
HIE has both ASOS and a clearance deliveray frequency. I guess they just
want to be able to do pattern work or scud-running under a 700' ceiling.
--Gary
Old August 12th 04, 01:35 PM
Gary Drescher
"Barry" wrote in message ...
Often, though, the only available approaches have an MDA that's still within
Class E. In that case, there's no problem seeing and avoiding VFR aircraft
in the uncontrolled space underneath. Not so at HIE, however.
--Gary
Old August 12th 04, 02:01 PM
Barry
Pilots should be aware that HIE is not at all unusual in this regard - it's
very common to have an MDA below 700 AGL with no surface Class E. There are
also ILS approaches with DH at or near 200 and no surface Class E.
Old August 12th 04, 02:07 PM
hlink.net...
and
--Gary
As Steve said, not only does the airport have to have approved weather
reporting service and communications, the regional FAA office has to determine
a need for a Class E surface area. AOPA fights these tooth and nail as an
"airspace grab," so the FAA policy is to not establish them except under
certain circumstances. The regional FAA Flight Procedures Office is in the
best position to explain that policy to you.
Old August 12th 04, 03:44 PM
Gary Drescher
determine
Thanks, perhaps I'll ask them. So far all of my IMC approaches have been to
Class B, C, or D airports, so I haven't been very concerned about this
issue. But it does seem to me that the safety of being in controlled
airspace during the approach until below the MDA would outweigh the
usefulness of being able to fly VFR under a 700' ceiling (especially at HIE,
surrounded by hills and mountains).
--Gary
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 03:29 AM
Meigs Class D Airspace Defly Instrument Flight Rules 0 July 19th 04 03:53 PM
Transiting KCLE Class B dutch Instrument Flight Rules 6 April 22nd 04 04:17 AM
vfr corridors through class B airspace [email protected] Instrument Flight Rules 26 November 3rd 03 12:28 AM
IA to Class E Sydney Hoeltzli Instrument Flight Rules 6 July 14th 03 03:29 PM
