MA3 carb
Old September 7th 06, 07:58 AM posted to rec.aviation.homebuilt
Philippe Vessaire
Default MA3 carb
Hello,
I have a straight fuel inlet (AN940 style).
May I bolt a 90° fuel inlet (AN842 style)?
Is it possible to use AN842 or do I need other parts numbers?
Thanks
Pub: http://www.slowfood.fr/france
Philippe Vessaire Ò¿Ó¬
Old September 7th 06, 08:09 PM posted to rec.aviation.homebuilt
John Kunkel
Default MA3 carb
"Philippe Vessaire" wrote in message
Hello,
Do you mean AN(8)40? As long as the pipe thread size is the same and there
is clearance to swing the 90° fitting, the AN842 should work just fine.
Marvel carb on C-75--data needed [email protected] Owning 7 March 27th 06 12:42 PM
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 01:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 07:26 PM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 03:32 PM
