Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aviation Marketplace
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup
Old September 7th 06, 08:23 PM posted to rec.aviation.marketplace,rec.aviation.misc,sci.electronics.repair
Juan Jimenez[_1_]
Default Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup
The Vintage Flying Museum at Meacham Field in Fort Worth, Texas,
(http://www.vintageflyingmuseum.org) an IRS-approved non-profit
organization, is looking for five vacuum tubes to complete its static
display of a B-17 WW2 bomber "SCR-287-A liason radio station" setup. They
have already received donations of quite a few components, but they are
still missing a few others. The museum owns and regularly flies "Chuckie" --
a B-17G aircraft.
They need four NON-FUNCTIONAL VT-4-C and one VT-25 vacuum tubes (they don't
have to work, there's no plan to make the setup operational, they just want
it to look complete).
They are also looking for:
DM-28 - Dynamotor for BC-348 receiver (any letter suffix OK!)
FT-142A - Mounting Tray for BC-306A antenna coupler
FT-107 - Mounting Tray for PE-73C dynamotor
PL-59 - Connector (need 2)
PL-61 - Connector (need 2)
PL-64 - Connector
SA-13 - DPDT knife switch (antenna selector switch)
BC-461 - Trailing Antenna Control Box
RL-30B - Trailing Antenna Motor and Spool
F-10 - Antenna Fairlead
MC-163 - Trailing Antenna
If you have non-working vacuum tubes or any other components on the list
which you wish to _donate_ (all donations are tax-deductible), please
contact them at . Their contact info is:
505 NW 38TH ST. Hangar 33 South
Fort Worth, Texas 76106
Phone (817) 624-1935
Fax (817) 624-2840
Posted via a free Usenet account from
http://www.teranews.com
Old September 7th 06, 09:16 PM posted to rec.aviation.marketplace,rec.aviation.misc,sci.electronics.repair
Michael A. Terrell
Default Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear forB-17 setup
a B-17G aircraft.
PL-64 - Connector
Fax (817) 624-2840
news:rec.radio.amateur.boatanchors
news:rec.antiques.radio+phono
Service to my country? Been there, Done that, and I've got my DD214 to
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Old September 9th 06, 01:39 AM posted to rec.aviation.marketplace,rec.aviation.misc,sci.electronics.repair
jerry wass
Default Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gearfor B-17 setup
a B-17G aircraft.
PL-64 - Connector
Fax (817) 624-2840
Do you have the civilian NUMBERS FOR THE VACUUM TUBES ??
Jerry
Old September 9th 06, 01:50 AM posted to rec.aviation.marketplace,rec.aviation.misc,sci.electronics.repair
Michael A. Terrell
Default Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gearforB-17 setup
Jerry
That kind of defeats the purpose of displaying military radios,
doesn't it? There are plenty of the original tubes around, and a lot of
people mount a dead tube on a piece of Walnut to use as a paperweight,
or they display the old tubes in large shadowboxes.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Old September 9th 06, 03:21 AM posted to rec.aviation.marketplace,rec.aviation.misc,sci.electronics.repair
Don Tuite
On Fri, 08 Sep 2006 23:39:43 GMT, jerry wass
a B-17G aircraft.
PL-64 - Connector
Fax (817) 624-2840
The military tubes often had different base configurations and
filament voltages than their civilian counterparts. For example, the
1625 is an 807 with a 12-V filament instead of a 6.3-V filament and a
different pin-out.
Thing is, the Victor-Tare numbers above are not what was printed on
the tubes. Here's a cross-reference to the JAN numbers:
http://members.aol.com/djadamson7/articles/vt.html
Don
Old September 13th 06, 07:14 PM posted to rec.aviation.marketplace,rec.aviation.misc,sci.electronics.repair
Juan Jimenez[_1_]
"jerry wass" wrote in message
"Chuckie" -- a B-17G aircraft.
don't have to work, there's no plan to make the setup operational, they
just want it to look complete).
PL-64 - Connector
Fax (817) 624-2840
Look them up on Google or eBay, no need for "civilian numbers".
Old September 18th 06, 05:33 PM posted to rec.aviation.marketplace,rec.aviation.misc,sci.electronics.repair
Bill[_4_]
I saw a thing floating around about the restoration of Enola Gay.
http://aafradio.org/NASM/Enola_avionics_narrative.htm
They were worried about things like the vacuum tubes having
the correct date codes.
So they probably would not have wanted the civilian equivalents!!
Bill Hale
a B-17G aircraft.
PL-64 - Connector
Fax (817) 624-2840
Old September 19th 06, 11:20 PM posted to rec.aviation.marketplace,rec.aviation.misc,sci.electronics.repair
Juan Jimenez[_1_]
This setup will not be located in the aircraft, it will be on a static
display in the museum.
"Bill" wrote in message
Bill Hale
"Chuckie" --
a B-17G aircraft.
don't
want
PL-64 - Connector
Fax (817) 624-2840
Posted via a free Usenet account from http://www.teranews.com
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup Juan Jimenez General Aviation 7 September 19th 06 11:20 PM
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 02:59 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
