IMPORTANT- Seeyou V's Strepla and airspace violations.
Old September 10th 06, 07:40 PM posted to rec.aviation.soaring
Default IMPORTANT- Seeyou V's Strepla and airspace violations.
OK in order to sort a dispute that is running between Ramy and myself.
I have Strepla which shows minor airspace and altitude violations which
Seeyou does not.
FYI. Ramy's Logger Calibration report shows a +169ft error at 18000ft.
The flight in question is this one here .
http://tinyurl.com/fe2k8
I ask users of both software to look at this flight and report their
findings.
If this exercise highlights a bug in Strepla I owe Ramy an apology.
Thanks
Al
Old September 10th 06, 08:11 PM posted to rec.aviation.soaring
Ramy
And while awaiting for Al's appology, I decided to no longer post my
flights to olc. I am sure I am not going to be the only one with this
decision .
Signing off,
Ramy
Seeyou does not.
findings.
Thanks
Al
Old September 10th 06, 08:20 PM posted to rec.aviation.soaring
Marc Ramsey
Anal nit-picking has now become the most important aspect of soaring,
apparently, thanks to the SSA-OLC collaboration...
Seeyou does not.
Strepla is clearly wrong on the altitude, as I told you privately, I
carefully extracted all of the pressure altitude data from the IGC file,
and there wasn't a single fix that exceeded 18,000 feet, once corrected
for the *landing* altitude and calibration error. I invite you to do
the same.
The airspace problem is more complicated, we're talking a hundred or so
feet either side of the boundary. Given that there are not two, but
actually three pieces of software involved (SeeYou, Strepla, and
WinPilot), minor calculation errors in any of them could put one on
either side of the boundary. I have no desire to put any energy into
figuring out how the fixes in the IGC file relate to the published
airspace boundary, but perhaps someone else does.
I believe you owe Ramy an apology in any case, it is ridiculous to be
wasting time on violations that don't amount to much more than 100 feet,
at worst.
Marc
Old September 10th 06, 08:46 PM posted to rec.aviation.soaring
JS
Marc
Total Madness. (Which is a great compilation of ska tunes from a band
that could teach us all to lighten up.)
Old September 10th 06, 09:07 PM posted to rec.aviation.soaring
Marc you TOLD me that you had reviewed please pass along the file or
other data that supports your claim.
Enough hearsay as there is obviously a software error here on either
Seeyou or Strepla.
Lastly is a 100ft or 1000ft violation any different. it is still an
incursion either way you look at it.
I would be curious to here that form contest scorers.
I remember a case a while back a pilot was allowed a turnpoint in a
contest even though the GPS point was not in the turn zone. It was
later protested out and his flight devalued.
Thanks
Al
Seeyou does not.
the same.
at worst.
Marc
Old September 10th 06, 09:15 PM posted to rec.aviation.soaring
588
decision .
Excellent!
If it ever stops raining, I move to the head of the pack -- only need
about 15,000 more points.
Jack
Old September 10th 06, 10:18 PM posted to rec.aviation.soaring
Doug Haluza
I think you owe him an apology. Using SeeYou and setting QNH (5888ft)
at the start, gives a max altitude of 18,261 MSL. But this gives a
final altitude of 4819 MSL at an airport elevation of 4697'. This means
the altimeter setting changed during the flight, and the change made
the altitude appear to be high by more than 100' at the end. So this is
a mitigating facor.
Even neglecting this, an 18,261' altitude from this logger is within a
reasonable error budget.
First we have to allow that the pilot is not using the logger as his
primary flight reference altimeter. The altimeter is subject to certain
errors, and the errors increase with altitude. Adding these errors
could explain most, if not all of the 261' deviation in the worst case,
even if the altimeter was calibrated for IFR flight.
Ramy reports that the logger has a calibration error of +169 feet at
18000 feet. We would also need to know the error at around 5000 feet to
account for using field elevation for the initial setting. But unless
the error at 5000' was more than +169 feet (which is unlikely), this
would further mitigate the discrepancy.
The other thing that adds to the error is that the Volkslogger is using
cockpit static venting. This will cause a variable error depending on
canopy sealing, vent position, etc. Also the logger is calibrated at
room temperature, and it was probably quite a bit colder at 18,000'.
The bottom line of this is that we can't say that he did not go above
18,000', but we can't say that he did either. We could reduce the
uncertainty somewhat if we had an ATC altimeter setting, but it's not
likely to change the analysys much. So in this case, we have to take
the pilot at his word when he says he did not bust Class-A. We really
should not get into this kind of hair splitting anyway, because it is
not productive.
This also shows why these kind of disputes are better handled in
private, as I have been repeatedly requesting here. Please contact the
pilot if you can and politely point out your concern. If you do not get
a satisfactory explanation, do not start a confrontation. Contact the
SSA-OLC Committee by email at olcatssadotorg (use the symbols to
get a valid address). We will handle the issue confidentially to
protect all parties from embarrassment. If we find that the flight log
shows a problem, we will ask the pilot to remove the flight claim. If
not, we will put a note on the claim to explain the discrepancy.
Now let me add one note of caution. You will need to allow a safe
margin below 18,000' MSL when flying to account for altimeter (and
pilot) error. A 500' buffer would be prudent, unless you kept your
altimeter calibrated for IFR flight (or had a calibrated transponder
encoder with readout corrected for altimeter setting).
Either this pilot was using a buffer with an altimeter that read low,
or he was not using a buffer with an altimeter that did not read low.
We don't know for sure. But if your altimeter reads low, or the
altimeter setting changes and you don't reset it often, you could have
a bust that cannot be explained away. In this case, all the factors
fell in the pilot's favor, but you may not be so lucky.
Doug Haluza
SSA-OLC Admin
Seeyou does not.
findings.
Thanks
Al
Old September 10th 06, 10:54 PM posted to rec.aviation.soaring
Frank Whiteley
~ wrote:
Looking at the barograph on the OLC it does not go above 6000 meters 3 times
6000 is 18000ft
Was it flown off a certified tested altimeter as lag and error in the
altimeter or pressure transducer would account for error as well as pressure
changes during the day !
however 3.28ft/m*6000m=19680ft
Old September 10th 06, 10:55 PM posted to rec.aviation.soaring
6000 is 18000ft
Old September 10th 06, 11:37 PM posted to rec.aviation.soaring
Mike Schumann
Why the emphasis on keeping everything private all of the time? That just
makes people think that things are being covered up. If there are issues,
there's no reason for them not be discussed civilly in public. That way
everything is on the up and up, and everyone else can learn something in the
process.
Mike Schumann
"Doug Haluza" wrote in message
a mitigating facor.
not productive.
Doug Haluza
SSA-OLC Admin
Seeyou does not.
findings.
Thanks
Al
Commercial - StrePla Update Paul Remde Soaring 0 May 19th 04 03:52 PM
