While checking my new Garmin 496 power/data cable, I put a scope on the
NEMA DATAOut line. Just like the EI instruments, the Garmin puts out TTL (0V and 4V) logic levels instead of the normal RS232 voltage levels (-5V / -12V to +5V /+12V) Do all aircraft systems that communicate via "RS232" use the TTL levels? How about if I drag my Labtop out to the computer to read some diagnostics or upload a new database? |
mikem wrote:
While checking my new Garmin 496 power/data cable, I put a scope on the NEMA DATAOut line. Just like the EI instruments, the Garmin puts out TTL (0V and 4V) logic levels instead of the normal RS232 voltage levels (-5V / -12V to +5V /+12V) I had a gadget (Caller ID interface) that was designed to plug into the serial port of a PC. It didn't have an onboard way to generate the negative voltage - no dual power supply, nor a MAX232 or similar chip. Instead, it depended (IIRC) on one of the handshake lines on the PC being set to mark (negative voltage), and used a transistor to switch this voltage onto the data line when a mark was needed. I think you could even use the transmit line from the PC as the source of the negative voltage (it idles in mark), as long as you could guarantee that the software on the PC wouldn't try to talk and listen at the same time - in other words, half duplex. If you have an RS232 breakout box, or a cable you don't mind cutting up, you might connect the Garmin to your laptop through the box/cable and see what the voltage levels look like then. Matt Roberds |
mikem wrote:
While checking my new Garmin 496 power/data cable, I put a scope on the NEMA DATAOut line. Just like the EI instruments, the Garmin puts out TTL (0V and 4V) logic levels instead of the normal RS232 voltage levels (-5V / -12V to +5V /+12V) Do all aircraft systems that communicate via "RS232" use the TTL levels? How about if I drag my Labtop out to the computer to read some diagnostics or upload a new database? Is the idle line up or down? If it's cheated RS-232 (negative half missing), the idle level is down. If it's logic level, the idle line (marking) is up. For a logic-level line you need a MAX232 or clone to create correct RS-232 levels. For a cheat RS you need additionally a logci inverter ahead of the buffer. HTH -- Tauno Voipio (OH-PYM, PA28RT201T) tauno voipio (at) iki fi |
Tauno Voipio wrote: .... Is the idle line up or down? Down, which I think you are saying means that the signal I see is the same polarity as full-blown RS232 levels, but the amplitude is reduced to only 4V p-p. (0 to 4V). Obviously, the trip point of the receiver of such a reduced amplitude signal would have to be at about 1.5V (TTL like). Thanks, |
Peter wrote: TTL (0V and 4V) logic levels instead of the normal RS232 voltage levels (-5V / -12V to +5V /+12V) No idea. There are some suspect practices in avionics though, like wiring multiple receivers to a single RS232 transmitter. They should be using RS422 for that. RS-232 is being BADLY abused these days. The spec only requires more than 3 Vdc or less than -3 Vdc, and a lot of modern laptops settle on 3.3 as "okay." It's rare to find one that actually puts out +/- 12 any more. I too have "cheated" for quick and dirty interfaces. TTL out will usually drive an RS-232 input (although not always). Inputs? Put a couple of protection diodes and a resistor in front of a CMOS gate and you can receive RS-232 without any special stuff - but you give up half your noise immunity. I agree - for aircraft differential RS-422 is much better (or ARINC 429). jmk |
Peter wrote: What interface is ARINC? Isn't it RS422? "jmk" wrote I agree - for aircraft differential RS-422 is much better (or ARINC 429). No. ARINC-429 is the most common avionics bus on commercial airliners. Electrically it is +/- 10 Vdc, return-to-zero, differential pair. There are two speeds, one around 100 kbps and one down around 12,500 bps. Very tight limits on rise and fall times. Software wise, it's pretty much fixed message length (packets), with most of the message types pre-defined (international standard). It's not hard to implement, but if you want to meet the drive specific conditions (rise/fall times, loading) you either have to implement your own circuitry with a bunch of op amps, or use one of the very few -429 driver chips out there. There is a good tutorial at: http://www.condoreng.com/support/dow...NCTutorial.pdf |
| Thread Tools | |
| Display Modes | |
| Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue | Mike | Naval Aviation | 26 | July 12th 06 12:38 AM |
| Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 03:39 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
