LX4000 and PDA
Old September 20th 06, 02:30 PM posted to rec.aviation.soaring
Gabriel Duford
Default LX4000 and PDA
Hi!
Is there a way to connect an LX4000 into a PDA?
I am pretty sure there is an output on the LX4000, but there's no info
in my english version of the manual and the only manual available from
LX-Navigation is for v5.3 and is in German and doesn't have wiring
diagrams. I have an electronic German manual for v8.3 (which I have in
my LX4000) but there's no details about the output wiring.
My setup is: LX20 as logger and GPS source for the LX4000.
I'd like to: connect the PDA in the LX4000 to run something like XCSoar
or GPS_LOG.
gabriel
Old September 20th 06, 04:18 PM posted to rec.aviation.soaring
Paul Remde
Hi Gabriel,
I suggest you send an e-mail to . I have received
many wiring diagrams from them upon asking in the past.
If you can't work it out yourself I can create a custom wiring harness for
you.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Gabriel Duford" wrote in message
ps.com...
Hi!
or GPS_LOG.
gabriel
Old September 20th 06, 04:42 PM posted to rec.aviation.soaring
Gabriel Duford
Thank you Paul, I will email them.
Do you know if the LX4000 will send more than just a repeat of the NMEA
received from the GPS? Will it add some "compensated vario"
information that the software on the PDA can use (a little like the
LX1600 and many other varios do)?
Thanks again,
gabriel
p.s. Gilles-Andre, j'ai recu ton email, mais une erreur "unknown user"
me revient lorsque je reply. As-tu un autre email?
Paul Remde wrote:
Hi Gabriel,
you.
Good Soaring,
Paul Remde
ps.com...
Hi!
or GPS_LOG.
gabriel
Old September 20th 06, 05:16 PM posted to rec.aviation.soaring
Richard[_1_]
Gabriel,
I don't believe the LX4000 outputs vario data. But you can get Nav data
to your Pocket PC. Split the RX, TX, Ground from your LX20. Then to
a power converter Craggy Aero PWR-5B. This will pass the RX, TX data
to the Pocket PC and provide +5v to power the Pocket PC. A Y cable
could also be made to Supply RX, TX, GND to the LX4000 and RX, TX,
GND, 12v to the LX 20 from the PWR-5B.
Richard
www.craggyaero.com
Gabriel Duford wrote:
Hi!
or GPS_LOG.
gabriel
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
Copyright ©2004-2026 AviationBanter.
