Anti-fog window spray?
Old October 15th 06, 04:05 PM posted to rec.aviation.owning
Peter R.
Default Anti-fog window spray?
What is a good anti-fog spray for the interior aircraft windows?
Departing during Buffalo's lake effect snow last Thursday, I had my plate
full as it was when about 1,500 feet above the ground the interior of my
Bonanza's windows glazed over in a fog that quickly turned to ice.
Peter
Old October 15th 06, 11:22 PM posted to rec.aviation.owning
Good gosh,, that would have been a nightmare. If it happened that fast
anti-fog spray would not do much. Good ol cabin heat and alot of it is
a wonderful thing in that scenerio.
Ben
www.haaspowerair.com
Peter
Old October 16th 06, 12:02 AM posted to rec.aviation.owning
Peter R.
" wrote:
snip
Of course. It wasn't quite the nightmare that it may have seemed,
given that outside was IMC due to moderate snow and clouds.
Fortunately the band of snow extended only about 20 miles east, the
direction I was flying, and I left it above a broken layer at 11,000 feet
with sunshine above. Between the heat, the fresh air vents, and the
sunshine, the windows eventually cleared.
Peter
Old October 16th 06, 12:24 AM posted to rec.aviation.owning
Ben Jackson
Divers and snorkelers use spit!
Ben Jackson AD7GD
http://www.ben.com/
Old October 16th 06, 05:15 AM posted to rec.aviation.owning
David Lesher
"Peter R." writes:
You didn't stay and enjoy all the fun???
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old October 16th 06, 05:07 PM posted to rec.aviation.owning
Peter R.
Luckily not. Buffalo really got nailed that night and early Saturday
morning.
Peter
Old October 16th 06, 05:27 PM posted to rec.aviation.owning
Longworth[_1_]
x-archive-no: yes
What is a good anti-fog spray for the interior aircraft windows?Divers and snorkelers use spit!
Spit can work to reduce fog but not as effective or long lasting
as anti-fog solution (which can be substituted with shampoo). I use
spit for my swim goggles and baby shampoo for my diving mask (just
smear a few drops then rinse off with water). I'd think that any kind
of shampoo will work but the baby shampoo does not irritate your eyes.
It does not hurt to try rubbing some diluted shampoo solution on the
interior aircraft windows to see if it helps to reduce fogging.
Hai Longworth
Old October 16th 06, 05:47 PM posted to rec.aviation.owning
Dave Butler[_1_]
This stuff works on swim goggles:
http://www.aquagoggles.com/zerofog.asp
Old October 17th 06, 05:19 AM posted to rec.aviation.owning
Peter R.
Interesting. No mention of whether it is safe to apply to plexiglass that
I can see.
Peter
Clear and Amber window for KY197 Roger Owning 5 June 11th 06 11:56 PM
Clear and Amber window for KY197 Roger Home Built 5 June 11th 06 11:56 PM
Side window install Jim Burns Owning 3 August 11th 05 04:59 PM
Scout/Citabria Window Tom Johnson Soaring 0 October 31st 04 07:35 PM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 01:19 PM
