Motion LS800 table HD failure at 14,000 feet
You may want to check with a computer hardware group, but
here are my comments. Hard drives fly the read/write head on the air cushion over the platters. As the air gets thinner at altitude, the head crashes. You may be able to find hardware rated for altitudes up to FL180 or even higher. You can contact the hard drive and laptop makers to see what options they have. You have found why avionics cost more than consumer grade and budget computers. Try Google and search for key words. "Peter" wrote in message ... |I am a PPL/IR private pilot, running various GPS apps (notably Jepp | Flitedeck) on a Motion LS800 table PC. | | The hard drive packs up at around 14,000 feet, crashing the unit. | | Flash alternatives (I believe it is a 1.8" HD inside) are extremely | costly, around USD 2000 for 8GB, and I wonder how successful it would | be to put in a 4GB SD card (for which there is a slot), put all maps | on that, etc. | | The problem is that Windoze itself accesses various bits of the HD | anyway, and does anyone know which bits, and can they be moved to the | SD card? | | Has anyone tried this? | | I reckon that, as a minimum, one would need to move the windoze | swapfile, and registry, to the SD card. Once upon a time I had to run | a program called Filemon to monitor disk accesses, to see why an auto | power-down SCSI HD would keep powering back up again, and I found a | registry access every 1 second or so, plus an access (for no apparent | reason) to every fixed HD every few minutes. This was on NT4 though. |
"Jim Macklin" wrote in message news:y4HYg.3149$XX2.1495@dukeread04... You have found why avionics cost more than consumer grade and budget computers. Oh please... This is an issue of mission profile, not FAA certification. -- Posted via a free Usenet account from http://www.teranews.com |
Similar Threads | ||||
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
