When I lower the wing flap handle why don't they?
Old October 17th 06, 04:02 AM posted to rec.aviation.piloting
Jim Burns
Default When I lower the wing flap handle why don't they?
flap that is?
Old October 17th 06, 04:15 AM posted to rec.aviation.piloting
Don Tuite
On Mon, 16 Oct 2006 21:02:58 -0500, "Jim Burns"
flap that is?
Pump it up and down faster.
Don
Old October 17th 06, 04:16 AM posted to rec.aviation.piloting
Emily
Jim Burns wrote:
flap that is?
You must be lowering the wrong handle. Mine flap.
Old October 17th 06, 04:21 AM posted to rec.aviation.piloting
tony roberts
flap that is?
Wine were the same - finally found the problem.
You need to remove a few nuts & bolts
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old October 17th 06, 04:22 AM posted to rec.aviation.piloting
BT
ok Mxsanic... how did you make us think you were Jim..
"Jim Burns" wrote in message
flap that is?
Old October 17th 06, 05:59 AM posted to rec.aviation.piloting
Jim Burns wrote:
flap that is?
It's getting colder out; your bird is trying to conserve fuel. Try
pouring about half a pound of sunflower seeds into it and then try
again.
Matt Roberds
Old October 17th 06, 07:06 AM posted to rec.aviation.piloting
Jim Burns wrote:
flap that is?
Did you tar and feather the prop first?
Old October 17th 06, 07:17 AM posted to rec.aviation.piloting
cjcampbell
Emily wrote:
Jim Burns wrote:
flap that is?
Yes. On the Baron 58 the flap handle and the gear handle are often
reversed.
Old October 17th 06, 09:11 AM posted to rec.aviation.piloting
Jim Macklin
Beech was correct in the old airplanes, flaps close to the
throttle and the landing gear a long reach. Mooney went one
better with their gear switch on some models at the top
center of the instrument panel
But Cessna built 5-10 times as many airplanes as Beech so
the FAA adopted the Cessna pattern in Part 23.
James H. Macklin
ATP,CFI,A&P
some support
"cjcampbell" wrote in
message
| Emily wrote:
| Jim Burns wrote:
| flap that is?
are often
| reversed.
Old October 17th 06, 09:13 AM posted to rec.aviation.piloting
Jim Macklin
I put my flaps down and my longjohns broke the buttons on
the rear.
| Jim Burns wrote:
| flap that is?
Grob G102 Setup BDS Soaring 11 August 30th 05 04:42 PM
Negative flaps for better low speed aileron control? [email protected] Soaring 41 August 25th 05 07:01 AM
Flap handle activated Climb/Cruise switching Andy Smielkiewicz Soaring 5 March 14th 05 05:54 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 03:33 AM
