What's the proper procedure to execute a forward slip, how should the
aircraft be expected to react when it is performed, and what are the main uses of the forward slip? And why is it called a _forward_ slip? I've been reading about this, and from what I understand, the procedure is to roll to one side and hold the rudder to the opposite side. I've tried this in the sim. The aircraft rolls to the side I'm rolling it to, and then seems to slide downward almost in the same plane as the wings, only a bit steeper. Altitude is lost very quickly indeed, but airspeed stays steady. Is this what happens in real life? Am I doing it correctly? What's the correct procedure to return to level flight? Somebody said that MSFS cannot simulate forward slips correctly. What is missing in the simulation? Note that, by default, MSFS is configured to link the rudder to the ailerons. All turns are forced into coordinated turns, and there's no independent rudder control. This can be turned off to improve realism. But with this default option enabled, it's impossible to perform any maneuver that requires rudder control independent of aileron control. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Mxsmanic" wrote in message
... What's the proper procedure to execute a forward slip, how should the aircraft be expected to react when it is performed, and what are the main uses of the forward slip? And why is it called a _forward_ slip? http://www.faa.gov/library/manuals/a...lane_handbook/ |
"Mxsmanic" wrote in message ... What's the proper procedure to execute a forward slip, how should the aircraft be expected to react when it is performed, and what are the main uses of the forward slip? And why is it called a _forward_ slip? A forward slip is a way of losing altitude rapidly without gaining substantial airspeed, essentially by placing the airplane in a stable condition in which the wings are less-effective. Another use of a slip is to align the aircraft with the runway during a crosswind. Executing a forward slip, for its most basic flight-sim-type purposes, involves lowering one wing with the aileron and using opposite rudder to keep the aircraft oriented; it can be dangerous at slow speeds because the crossed controls create a perfect condition for spin entry on a stall during short final. The oppose rudder (if left wing is dipped, right rudder is applied) introduces drag as the tail is no longer aligned with the direction of travel, and the airflow comes over the wing at an angle instead of direct, reducing the component of lift across the airfoil. Three basic rules about slipping on final are 1) Don't stall, 2) Don't stall and 3) Don't stall. -c |
gatt wrote:
Three basic rules about slipping on final are 1) Don't stall, 2) Don't stall and 3) Don't stall. And ... 4) The ground will catch you... |
"Gary Drescher" wrote in
: "Mxsmanic" wrote in message ... What's the proper procedure to execute a forward slip, how should the aircraft be expected to react when it is performed, and what are the main uses of the forward slip? And why is it called a _forward_ slip? http://www.faa.gov/library/manuals/a...lane_handbook/ He won't read it :-( Allen |
gatt wrote:
"Mxsmanic" wrote in message ... What's the proper procedure to execute a forward slip, how should the aircraft be expected to react when it is performed, and what are the main uses of the forward slip? And why is it called a _forward_ slip? A forward slip is a way of losing altitude rapidly without gaining substantial airspeed, essentially by placing the airplane in a stable condition in which the wings are less-effective. Another use of a slip is to align the aircraft with the runway during a crosswind. Executing a forward slip, for its most basic flight-sim-type purposes, involves lowering one wing with the aileron and using opposite rudder to keep the aircraft oriented; it can be dangerous at slow speeds because the crossed controls create a perfect condition for spin entry on a stall during short final. The oppose rudder (if left wing is dipped, right rudder is applied) introduces drag as the tail is no longer aligned with the direction of travel, and the airflow comes over the wing at an angle instead of direct, reducing the component of lift across the airfoil. Three basic rules about slipping on final are 1) Don't stall, 2) Don't stall and 3) Don't stall. Right. The first turn of a spin will lose about 500' or more. Not good if you are pulling from a long base to final. And, you probably won't have enough rudder to get it out. |
Make sure you have the flaps fully deployed when you do it....
wrote in message ups.com... Make sure you have the flaps fully deployed when you do it.... ![]() Especially if it is a C-172N with the placard that says "Avoid Slips with the Flaps Extended" while on a checkride... :-) |
Mxsmanic wrote: What's the proper procedure to execute a forward slip, how should the aircraft be expected to react when it is performed, and what are the main uses of the forward slip? And why is it called a _forward_ slip? http://en.wikipedia.org/wiki/Slip_(aerodynamic) Somebody said that MSFS cannot simulate forward slips correctly. What is missing in the simulation? I've read it has something to do with its inability to calculate the lift, or perhaps just the default aircraft don't handle it. However, I believe some third party aircraft explicity address the slip issue. What's that C172 realistic addon? Drat. I've forgotten, but it's a far better 172 than the stock one. Note that, by default, MSFS is configured to link the rudder to the ailerons. All turns are forced into coordinated turns, and there's no independent rudder control. That's a major reason why simmers who don't own rudder pedals get little of the realism that the sim can sometimes offer. Kev |
gatt wrote: Three basic rules about slipping on final are 1) Don't stall, 2) Don't stall and 3) Don't stall. When I slip to landing, I always crank in some small forward (down) trim just in case I get distracted. Am I the only one that's this paranoid? Kev |
| Thread Tools | |
| Display Modes | |
| The smell of a decomposing mouse somewhere forward of the firewall | Peter R. | Owning | 23 | February 1st 06 04:52 AM |
| What is a "Forward Skip"? | Gary G | Piloting | 57 | January 7th 05 11:09 PM |
| Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 10:36 PM |
| B-17 forward guin positions | zxcv | Military Aviation | 13 | March 16th 04 01:04 AM |
| Forward Swept Wings | Canuck Bob | Home Built | 16 | October 3rd 03 06:50 PM |
