Outside air temperature probe
Old November 6th 06, 09:48 AM posted to rec.aviation.owning
dlevy[_1_]
Default Outside air temperature probe
I had a new windshield installed and don't want to drill a hole in the new
windshield for the old temperature probe. Is there a cheap alternative that
I won't have to drill the windshield to install?
Old November 6th 06, 09:52 AM posted to rec.aviation.owning
Bob Noel
The cheapest would be to mount it in a side window. For example,
cherokee owners mount the OAT probe in the little storm window.
An alternative is the Davtron M303.
Bob Noel
Looking for a sig the
lawyers will hate
Old November 6th 06, 10:56 PM posted to rec.aviation.owning
Robert M. Gary
On my Mooney I installed the remote temp probe in the pilot's air
eyeball air scoop, near your left knee. We then ran the wire behind the
panel to the EDM. It alarms at 0 C for icing.
-Robert
Old November 6th 06, 10:57 PM posted to rec.aviation.owning
Robert M. Gary
BTW: I once broke the windshield probe removing the plane cover. So I
was stuck in a remote area with a hole in the window I couldn't close.
So I flew it home. It was amazed that there was actually very little
air flowing through this open hole in the front of my windshield. I
guess most of the air runs up the window and doesn't want to make the
turn to enter the cabin.
Old November 6th 06, 11:10 PM posted to rec.aviation.owning
Jim Burns[_1_]
I've got the Davetron installed on the Aztec. We're happy with it and it's
surprisingly accurate.
"dlevy" wrote in message
that
Old November 7th 06, 01:40 AM posted to rec.aviation.owning
Mike Spera
I noticed a small crack starting from the probe about 2 years ago. Looks
like we stressed the WS when pulling off the cover. I really HATE to
stop drill it. It appears to be stable and not moving, so I may just
leave it alone and see what happens.
Old November 7th 06, 03:53 AM posted to rec.aviation.owning
zatatime
On Tue, 07 Nov 2006 00:40:19 GMT, Mike Spera
I had a similar issue except it was caused when I bumped it (very
lightly) when removing snow in below zero temps. My mechanic had some
very large flat washers and I drilled out the center and put one on it
(maybe one on the inside and outside, I'd have to check). Since then,
no more problems and no running cracks.
HTH.
z
Old November 7th 06, 03:26 PM posted to rec.aviation.owning
dlevy[_1_]
Thanks. That sounds perfect!
Did you run the wire through the vent to the outside?
new
that
-Robert
Old November 7th 06, 03:46 PM posted to rec.aviation.owning
dlevy[_1_]
I just bought the whole kit for $25 at mcmaster.com
news
new
that
-Robert
Old November 7th 06, 06:14 PM posted to rec.aviation.owning
Newps
You might want to set that a little higher, like +5 or so. Yesterday we
had moderate rime here between 11,000 and 14,000, temp was +4.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
CHT probe + resistor installed (final) Jim Burns Owning 8 September 10th 05 03:34 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Broken line to Oil Temperature Probe, Repairable? rkane33 Owning 2 July 25th 03 04:19 AM
