vor head needed
Old November 15th 06, 02:07 AM posted to rec.aviation.owning
blanche cohen
Default vor head needed
Well, the old (very old!) Narco VOR head died. Actually, I noticed it
was dead over a year ago, but it was on the 2nd nav/com so I really
didn't care. But I'm thinking of starting IFR training (again, for
the 3rd time) and the 2nd VOR would be nice.
Don't need the ILS portion, I have a perfectly good one on the 1st
nav/com.
Any suggestions?
Please do NOT suggest any panel-mount GPS units, don't have the
money right now (altho there's this perfectly good hole in the panel
just the right size for a 4xx....)
Old November 15th 06, 03:07 AM posted to rec.aviation.owning
Jim Burns
Ebay
Wentworth
Eastern
Gulf Coast
American
"blanche cohen" wrote in message
nav/com.
Any suggestions?
Old November 15th 06, 06:32 AM posted to rec.aviation.owning
Blanche
Jim Burns wrote:
Ebay
Wentworth
Eastern
Gulf Coast
American
nav/com.
Any suggestions?
I was hoping for manufacturer/model suggestions. I'm trying to get
away from the Narco stuff. The 2nd nav/com is a TKM slide-in
replacement for the Narco 12D
Old November 15th 06, 07:38 AM posted to rec.aviation.owning
RST Engineering
It would help if we knew the model number for the head. I've got a couple
of old ones from the original MK-12 you could have if that is what is dead.
Trying to connect apples to oranges is generally a fruit salad problem.
nav/com.
Any suggestions?
Old November 15th 06, 01:33 PM posted to rec.aviation.owning
Denny
Blanche, let me suggest that if you replace the VOR head that you
examine the cost of making it a VOR/ILS head... I have over the years
twice had a glide slope go bad while in IMC... Both times I finessed
my way out of it without any major sweat but it is nice when in actual
IMC to have a back up...
denny
Old November 15th 06, 05:32 PM posted to rec.aviation.owning
Blanche
Jim, et al:
I've got a dead Narco VOA4 sitting on the seat in the car. I don't think
it's even worth taking down to the instrument shop (at KAPA) to see about
repairing it, it's so old. I'll probably donate it to the local aviation
school's "museum".
And doing my homework (and I still don't know what I'm doing -- remember,
I do software, not hardware) I know that the TKM nav/com connects nicely to
Narco equipment (e.g. ID 824) but what about to a King? (e.g. KI201)
I'm still seriously considering the RST marker beacon unit, but you need
to understand that I barely know which end of the soldering iron to
hold (and I have the scars to prove it!) It's why I do software....
In Arizona summers, being in air conditioned offices was
much nicer than being in the shop.
Old November 15th 06, 05:35 PM posted to rec.aviation.owning
Blanche
Not a bad idea, but out here in the Rockies, if the weather is serious
IMC, then I'm not flying. Mostly this is for getting out of the airport
when the summer fog rolls in. There's not much difference in the
VOR v. VOR/ILS pricing. I need to see if the TKM unit contains the
stuff to talk to a glideslope.
Gadzooks -- you're making me go read the docs again.
Old November 15th 06, 05:49 PM posted to rec.aviation.owning
Denny
Ahh yes, but you are a software geek and manuals are soft - right?
The Narco/TKM will not drive King/Garmin/Collins indicator heads, but a
call to TKM could clarify that - or any avionics shop...
denny
Old November 15th 06, 05:59 PM posted to rec.aviation.owning
RST Engineering
I've got two old VOA-4 heads sitting SOMEWHERE in boxes of old instruments.
They were working when I took them out of the airplane twenty years or so
ago, and either one of them is yours if you want it. I'm going to go look
and see if I can find them, and I'd like to describe the connector on the
rear to you to see if it is the same one. As I vaguely recall, sometime in
the VOA-4's lifetime they switched connectors, and if this is the wrong one,
all you will get is grief trying to convert one to the other.
"Blanche" wrote in message
Jim, et al:
Old November 15th 06, 07:17 PM posted to rec.aviation.owning
RST Engineering
I found one of them. Let me describe the rear of the instrument to you and
see if it matches what you took out of your aircraft.
There are two adjustment controls on the rear. The top center one is
labeled LOC and the bottom right one is labeled VOR.
In the lower left corner there is what we call a "cannon" plug, about 1.25"
diameter and with 14 male pins inside the plug housing.
That what you've got?
Now, as I said, this one was working 20 years ago when I took it out to
replace it with the RST navcom(s). If it is DOA when you get it, start
thinking that perhaps it is the radio that drives the heads rather than the
heads themselves. What radio is driving the head?
If the radio is good, and this one doesn't work, I'll look around for the
other head.
"RST Engineering" wrote in message
Thrust Needed For Self Launching... tinman2006 Soaring 9 March 14th 06 01:38 AM
Thrust Needed For Self Launching... tinman2006 Soaring 0 March 12th 06 11:08 PM
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 07:23 PM
NY Go Kart Endurance Racing - Arrive & Drive - No Experience Needed OVRPNY Owning 1 May 19th 05 05:56 PM
builder assistance needed AINut Home Built 0 April 8th 05 08:05 AM
