Laister LP-49 for low time pilot
Old November 15th 06, 07:50 PM posted to rec.aviation.soaring
Jim Hultman
Default Laister LP-49 for low time pilot
There are few RAS comments on the Laister LP-49. In photos an ungainly
design, but does appear a reasonable transition ship for a low-timer; 31/1
LD, retractable gear, flaps, auto hookups, aluminum wing. How large is the
cockpit? Anyone here with LP-49 flying & rigging experience?
Jim Hultman
Old November 16th 06, 03:31 AM posted to rec.aviation.soaring
soarer999
I flew an LP-49 in the mid seventies--20 flights and 27+hrs. Our club
replaced a K-6E with the LP and I never really thought the LP measured
up to the K-6. The only good thing to be said for the LP is the metal
construction can weather the elements better. I do not remember any
difficulties with rigging but it has been a long time--30 years. Hard
to believe how time has passed. Lynn Wyman
Jim Hultman
Old November 16th 06, 07:56 AM posted to rec.aviation.soaring
N49LE (currently for sale) flew at my club for a few years. I never
flew it but helped rig and derig several times. It went together much
like any older metal ship: the wings weren't particularly heavy but it
helped to have two people on the root to keep it level fore and aft
while sliding it in place and there are several pins holding the wings
on. After rigging the turtledeck has to be installed and taped. More
fiddly and time consuming than a glass ship but not difficult. The
owner used to rig it and tie it down rather than rigging and derigging
every flight.
Old November 18th 06, 01:49 AM posted to rec.aviation.soaring
Jim Hultman,
I owned a LP-49 for a few years & put over 1400 hrs on it with 618
flights. Jack Laister, in my opinion, was a very good designer. I
believe it would be a very good ship for a low timer to transition
into. The cockpit was comfortable for my 185 lb.5ft 11" body. In it's
day it had a lot of features, spring loaded shock absorber retractable
landing gear, gear door went up inside the fuselage when the gear was
lowered. Two separate operations.Tailwheel retracted into the tail
cone at the same time gear was raised. The right materials were used in
the right place, molded fiber glass fuselage, aluminum wings & tail.
Wings tested to 12 g's. Stainless nose skid, simple brake system.
Trailing edge drive brakes where very effective. If I remember
correctly, it's been 26 years since I flew a 49, assembly although
not as easy as my 20, was not too bad.. The ship climbs like a home
sick angel. I highly recommend it.
Cliff Crader
Old November 18th 06, 07:15 AM posted to rec.aviation.soaring
Jim Hultman
Thanks for the comments! I went out to Walt's home in Perris, CA to look at
the Laister & discovered it has 0 hours. It was a kit he started, then had
no time for (he was a Continental Airlines captain). It was completed at the
Laister facility, then never flown. It's too small for me at 6'3". I doubt
anyone taller than 6'0" would be able to latch the canopy. Also, my
shoulders touched both canopy railings, but otherwise it felt similar to a
1-26.
31/1
Jim Hultman,
Cliff Crader
Safety pilot - logging cross-country S Herman Instrument Flight Rules 42 December 15th 05 08:27 PM
Can a Private Pilot tow gliders and get paid? zatatime Piloting 3 October 17th 04 02:35 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 03:13 PM
