Another of those unreliable AC engines stalled on approach
Old December 20th 06, 01:33 AM posted to rec.aviation.piloting
xxx
Default Another of those unreliable AC engines stalled on approach
Article reproduced in its entirety:
Pilot hurt in plane crash at Thetford airport
Published: Monday, December 18, 2006
THETFORD - A pilot from Post Mills was injured Sunday morning when the
plane he was piloting crashed at the Post Mills Airport in Thetford,
said state police in Bradford.
Andy Gelston, 45, was transported by helicopter to Dartmouth Hitchcock
Medical Center for unspecified injuries after the engine on his light
sport aircraft stalled at between 50 and 100 feet in the air and
crashed, nose first, at the end of the grass runway.
The Federal Aviation Administration is conducting an investigation.
Old December 20th 06, 02:37 AM posted to rec.aviation.piloting
Sylvain
This story does not make sense; if the aircraft was 'on
approach', I suppose it means landing, and looses its
engine 'between 50 and 100 feet in the air' I cannot see
why it would 'crash nose first at the end of the runway';
An aircraft does not fall out of the sky when the engine
quits. And in very short final (between 50 and 100 feet
in the air' it would be very short final indeed) it
would make no difference whatsoever that the engine is
running or not.
Another great moment in the history of journalism....
--Sylvain
Old December 20th 06, 02:51 AM posted to rec.aviation.piloting
The Old Bloke
"Sylvain" wrote in message
running or not.
--Sylvain
I assumed it was taking off.
Old December 20th 06, 02:59 AM posted to rec.aviation.piloting
Kyle Boatright
"xxx" wrote in message
What are the odds that the pilot stalled the aircraft and the engine was
performing just fine? Writers often miss the fact that the word "stalled"
has an additional meaning in the aviation realm.
KB
Old December 20th 06, 03:06 AM posted to rec.aviation.piloting
Peter Dohm
-------------end of original story----------------
running or not.
--Sylvain
And such moments become greater and more frequent...
Twenty five years ago, the technical expertise was similar; but the
linguistic precision was far better. We would not have been left to presume
whether it was the aircraft, or only the engine, which crashed nose first...
Peter
(Just being an old grump)
Old December 20th 06, 04:08 AM posted to rec.aviation.piloting
Crash Lander[_1_]
"Kyle Boatright" wrote in message
"stalled" has an additional meaning in the aviation realm.
KB
My thoughts exactly. What's the bet he tried to climb too steeply and
stalled it, dropped the nose as per his training, and found he wasn't as
high as he had hoped. I bet the engine was still running as he hit the
ground, and it's the journalist that's stalled.
Oz Lander
Peter
Only by careful reading can we assure ourselves that it was not the
PILOT that crashed nose first...
Old December 20th 06, 02:48 PM posted to rec.aviation.piloting
Stubby
Greg Farris wrote:
Judging from the town names, this accident happened in Vermont.
Post Mills is a tiny little grass strip.
Post Mills Airport (about 10 sm north of Lebanon) used to host the
Experimental Balloon Festival, usually in May of each year. A few small
aircraft were welcome as were helicopters. The last one I went to was
in 1999. I heard an experimental balloon on a tethered flight blew up
and crashed from 50' just after we left.
Old December 20th 06, 03:02 PM posted to rec.aviation.piloting
Judah
"xxx" wrote in news:1166574799.928243.156580
@f1g2000cwa.googlegroups.com:
snip
... the engine on his light
You should try to become somewhat educated before you take the words of
journalists as gospel.
Airplanes do not suddenly go extremely nose low simply because of engine
failure. They essentially become gliders and begin descending in a manner
that is typically controllable and gradual. Pilots are trained to manage
such a situation to maximize their glide ratio so they can find a suitable
place to land. I believe the typical glide ratio of a small airplane is
over a mile of glide distance for every 1000' of available altitude.
On the other hand, if the Pilot stalled the aircraft (either with or
without engine power) by not properly managing the airspeed across his
wings (for example by climbing too aggressively), the plane may lose its
lift (aka stall), and drop its nose somewhat suddenly.
Part of the Pilot Private Training syllabus focuses on recognizing the
onset of a stall early and being able to recover from such a stall within
50'. There is even a sensor on the plane's wing to sound an alert in the
cockpit if a stall is imminent.
It seems likely to me that the wing, not the engine, "stalled", causing the
plane to drop its nose suddenly, and crash into the ground. Possibly the
pilot did not have the proper training or attention to recover at such a
low altitude.
It is equally as likely that the journalist who wrote the article has no
background in aviation, and as such did not accurately interpret or report
the information collected. Rather than properly research the story, she met
her deadline and moved on.
Garmin 300XL GPS Approach didn't arm Steve S Instrument Flight Rules 9 May 11th 06 03:54 AM
Trust those Instruments.... Trust those Instruments..... A Lieberman Instrument Flight Rules 1 May 2nd 06 04:54 PM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 12:13 PM
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 03:51 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
