PDA/PC connection for NMEA feed
Old December 31st 06, 07:52 PM posted to rec.aviation.soaring
Default PDA/PC connection for NMEA feed
Okay, I know some folks have solved this problem before, but I haven't
been able to find the details in any old postings...
I have a PC running XP Pro with no 9-pin serial ports, just USB (though
the System panel does show a COM1). I have my PDA (an IPAQ 4700) in its
cradle and connected via USB, and both ends have COM1 set to 4800 baud.
The ActiveSync is disabled (disconnected). But I can't get WinPilot to
get the feed from SeeYou are Condor.
What can I try ... ?
~ted/2NO
Old December 31st 06, 08:29 PM posted to rec.aviation.soaring
Also, my iPAQ cradle does not have a 9-pin serial connector (USB only),
so I do not have the option of using a USB-to-Serial adapter to solve
the problem.
Old December 31st 06, 09:29 PM posted to rec.aviation.soaring
Paul Remde
Hi Ted,
I think you are confusing USB and RS-232 Serial data ports.
PDAs and soaring software receive GPS data over RS-232 serial ports only.
USB can be used with active sync, but not to connect to a GPS device.
You'll need an RS-232 port on the PC, or USB to RS-232 serial converter. I
prefer to use a PCMCIA RS-232 serial port in my laptop. That way there are
no issues with converters because it is an actual serial port. You can see
2 examples he
http://www.cumulus-soaring.com/pda.htm#SL0700-004
That would get your PC to talk RS-232 serial. You then need an iPAQ cradle
or iPAQ cable that can connect the iPAQ to the PC port.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
~ted/2NO
Old December 31st 06, 09:36 PM posted to rec.aviation.soaring
Can you tell me what settings you use? I've installed GpsGate on both
my PC and PDA but haven't gotten far beyond that.
I use GPSGate from Franson (http://franson.com/gpsgate/) on both the PDA
and PC. Not free, but works nicely over the usb connection.
Old December 31st 06, 09:57 PM posted to rec.aviation.soaring
Never mind -- got it figured out. This GpsGate thing is a good
solution.
On the PC, the GpsGate settings "Input" needs a new virtual comm port
opened (before running SeeYou or Condor), and the "Output" needs to be
set to ActiveSync.
On the PocketPC, the GpsGate's "Input" needs to be set to "ActiveSync"
and the "Output" set to a (new) virtual port, created by clicking "Add"
with "Virtual com port" selected.
Then, of course, SeeYou/Condor and WinPilot/SeeYouMobile need to be set
to use the respective virtual com port numbers.
Now my problem is WinPilot giving me this "Vario Data NOT PRESENT"
message every few seconds!!!
~ted/2NO
WingX Browser: Free Weather on your Pocket PC - no wireless connection required! Hilton Piloting 9 October 31st 05 02:56 PM
WingX Browser: Free Weather on your Pocket PC - no wireless connection required! Hilton Instrument Flight Rules 6 October 14th 05 08:12 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT Naval Aviation 4 April 3rd 04 04:17 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT General Aviation 4 April 3rd 04 04:17 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT Owning 4 April 3rd 04 04:17 AM
