Can gliders and powered aircraft co-exist on the same runway?
Old January 13th 07, 05:14 AM posted to rec.aviation.piloting
Ron Lee
Default Can gliders and powered aircraft co-exist on the same runway?
Can anyone identify and airport where gliders and powered aircraft use
the same runway? Do they use opposite traffic patterns? Any other
operational issues?
Ron Lee
Old January 13th 07, 05:47 AM posted to rec.aviation.piloting
BT
They can exist on the same runway.. but it would depend on the volume of
traffic of each type.
With a student doing touch and goes in the pattern, it would be difficult to
"stage and launch" a glider without a good ground crew that can push the
glider with the pilot already strapped in and ready for launch.
A large area near the threshold for staging and being able to "launch at an
angle to the runway and onto the runway" would work best. Also an area to
land and then have the glider "roll clear" to the side would also work best.
Runway side lights tend to cause a problem for this.
I would suggest opposite patterns so you can see each other on downwind and
base.
At our airport we are lucky to have parallel paved runways, one for glider
and one for power.
Multiple glider operations does cause congestion on the glider runway, we do
have a cleared infield and no runway lights on the "glider runway" so that
landing gliders can roll clear, or if the runway is blocked by a landing
glider, the next glider in the landing sequence can land on the infield, if
not long or short.
BT, CFIG
"Ron Lee" wrote in message
operational issues?
Ron Lee
Old January 13th 07, 06:34 AM posted to rec.aviation.piloting
I can think of two examples from my own personal experience:
1. Terry Airport (TYQ)- north side of Indianapolis, former home of the
Central Indiana Soaring Society, usually had right hand traffic for
gliders, which frequently used the parallel grass but would also use
the pavement. They are not there anymore because of big increase in jet
traffic at that airport.
2. Harnett County, North Carolina. Home of North Carolina Soaring
Assoc. much less busy airport, staged off the pavement for launching,
but would also use the grass to the side (not a formal strip) to land.
More traffic was overhead with the proximity to Fort Bragg and Pope
AFB. Also used right hand traffic for gliders.
-Ryan
Old January 13th 07, 09:22 AM posted to rec.aviation.piloting
chris[_1_]
operational issues?
Ron Lee
Matamata, New Zealand - very very wide grass runways, AFAIK it's
gliders one side, powered the other..
Old January 13th 07, 07:07 PM posted to rec.aviation.piloting
Doug Spencer
On Sat, 13 Jan 2007 04:14:45 GMT
operational issues?
Stanton (KSYN),
http://www.stantonairfield.com/ runs a lot of glider
operations on the same runways as powered traffic, including students
and sport pilots. Stanton Airfield is the headquarters of the Minnesota
Soaring Club.
The gliders use the same traffic patterns, but sometimes do a short
approach or enter on base leg or final rather than downwind. Glider
traffic has the right of way over powered aircraft. After landing, they
roll off to the side of the runway and are pulled back to the staging
area by a golf cart.
Powered traffic just lands beyond the staging area and taxis on the
opposite side of the runway.
Doug
For UNIX, Linux and security articles
visit http://SecurityBulletins.com/
Old January 13th 07, 08:50 PM posted to rec.aviation.piloting
george
operational issues?
Ron Lee
and Paraparaumu.
According to the AIP just about every airfield here (except AK, WGTN,
CHCH and Ohakea)
Old January 14th 07, 04:37 AM posted to rec.aviation.piloting
operational issues?
Ron Lee
5c1 north of San Antonio, Texas. Also known as Boerne Stage.
It has a paved runway used by both gliders and powered aircraft.
Parallel and close by is a grass strip. Powered and gliders can use
the grass, but it was usually used by gliders if the main runway was
occupied.
Traffic patterns were the same, IIRC. Of course, gliders had the right
of way. There were some pattern limitations due to nearby residents
who chose to live near an airport but didn't want to hear airplanes.
Neat place.
Old January 14th 07, 02:38 PM posted to rec.aviation.piloting
Ash Wyllie
B A R R Y opined
On 13 Jan 2007 20:41:2 -0500, "Ash Wyllie" wrote:
B A R R Y opined
Franconia NH, 1B5.
Is that where the gliders come from that see in the Nashua area?
Probably not, I suspect that it is a long way, through the notch, from Fanconia
to Nashua. And I bet it would seem even longer on the return trip.
-ash
Cthulhu in 2007!
Why wait for nature?
Old January 14th 07, 09:01 PM posted to rec.aviation.piloting
James
operational issues?
Ron Lee
At Dansville,NY, (KDSV) the gliders take off on a grass strip to the
right of 14, and fly a right hand traffic pattern. One day I was flying
into Dansville, and the winds were light and variable. The gliders were
departing from 14 (turf or right), and the tow plane was doing a 180 and
landing, flying straight in on the opposing runway, 32, on the bitumen.
It all sounded a bit different listening on the CTAF, to work out what
the active runway was, so I flew over the field and worked out what was
going on. The winds did favour slightly 14, so this could be a cause for
a concern for a head on type accident. I landed on 14 myself, once I
had worked out the 32 was being used purely for the convienience of the
tow plane.
James.
Hawker vs. Glider Midair - with photo! Larry Dighera Soaring 72 September 6th 06 03:03 PM
Hawker vs. Glider Midair - with photo! Larry Dighera Soaring 5 September 1st 06 08:20 PM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 04:28 AM
California Tax exemption - gone after Oct 1st Limus A. Soaring 1 August 6th 04 05:46 PM
