Do you assemble your glider paying good attention to it?
Old January 23rd 07, 01:53 AM posted to rec.aviation.soaring
Steve Leonard
Default Do you assemble your glider paying good attention to it?
Contestid67 wrote:
2) The NTSB report says that the wing separated 'at
wing-to-fuselage attachment point.' Wrong, it was clearly
outboard of that. Seems like an odd place for a multi
part wing to be coupled.
- John
The glider in the video has a 3 piece wing. The connection
where the wing seperated is the tip of the center section
and the root of the outer panel.
I have helped put one of these together. I do not
know if the wing would stay in place if the 'pin' had
not been rotated to expand and lock. A very worthwhile
test for the FAA to have run would have been to fully
extend the pins, then apply load like the spar would
have, and see if the pin would push out of the way.
If the pin is tapered, and the screw that drives it
into place allowed the pins to spin the jackscrew,
that could certainly have caused the pin to back out
under load. Since the aircraft has been sold for salvage,
we will probably never know.
Steve
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 11:46 PM
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 10:45 PM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 08:18 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 01:05 AM
