Human-powered gliders
Old January 28th 07, 07:56 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Human-powered gliders
I know that some gliders have small powerplants that they can use in
an emergency for thrust, but are there any gliders that are simply
powered by the pilot? Is the thrust required to keep a glider in the
air small enough that a human pilot could supply it for any length of
time? They seem very efficient, so it occurred to me that a crank or
pedals or something driving a small propeller might be sufficient to
stay aloft in bad situations. Would it?
Old January 28th 07, 08:10 PM posted to rec.aviation.piloting,rec.aviation.student
Casey Wilson
"Mxsmanic" wrote in message
No.
Old January 28th 07, 08:14 PM posted to rec.aviation.piloting
kontiki
A crank or pedals or something driving a small generator might be
sufficient to keep the computer running until it can be safely shut
down.
Old January 28th 07, 09:04 PM posted to rec.aviation.piloting,rec.aviation.student
Richard
No, man power has only worked in extremely light weight gliders.
http://en.wikipedia.org/wiki/Gossamer_Albatross
http://en.wikipedia.org/wiki/MIT_Daedalus
Old January 29th 07, 12:55 AM posted to rec.aviation.piloting
buttman
On Jan 28, 11:10 am, "Casey Wilson" wrote:
No.
OH MAN YOU SURE SHOWED HIM
Old January 29th 07, 01:52 AM posted to rec.aviation.piloting
Casey Wilson
"buttman" wrote in message
No.
What?
Old February 3rd 07, 06:42 PM posted to rec.aviation.piloting,rec.aviation.student
Frank
A trained person could generate just enough power to keep the Gossamer
Albatross in the air, which required 0.3 hp (200 W).
The power of a sustainer motor of a glider equals between: 18-30 hp (14-22
kW), so this is too much for a human pilot to supply.
Can gliders and powered aircraft co-exist using the same runway? Ron Lee Soaring 17 January 31st 07 09:42 PM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 04:28 AM
flexible wing human powered flight patrick timony Home Built 3 January 15th 04 01:21 AM
Underwater Gliders Burt Compton Soaring 6 November 25th 03 05:43 AM
human powered flight - vertical take off, flexible wing patrick timony Rotorcraft 2 September 18th 03 12:39 AM
