Which GRP single-seater has the lowest cockpit weight?
Old January 31st 07, 06:06 PM posted to rec.aviation.soaring
Dan G
Default Which GRP single-seater has the lowest cockpit weight?
A friend of mine weighs just 110lbs with parachute. With ballast, she
can fly some K13s and a couple of wooden single-seaters which have
particularly low cockpit min weights.
Which GRP single-seaters tend to have low min weights, and how much is
it?
Dan
Old January 31st 07, 06:33 PM posted to rec.aviation.soaring
phil collin
it?
Dan
2 words, Ballast Weights
Phil Collin
Partner Manager
T: 0845 862 1 862
E:
W:
www.voicehost.co.uk
Old January 31st 07, 10:39 PM posted to rec.aviation.soaring
Andreas Alin
I've read in a german forum: Older gliders ´got a minimum load of 65 kg,
because of the building regulations for all glider types in those times.
Newer building regulation say 75 kg.
With older types they mean e.g. ASW 15.
Andreas
it?
Dan
Old February 1st 07, 02:51 AM posted to rec.aviation.soaring
L33: 121 lbs
Old February 1st 07, 04:12 AM posted to rec.aviation.soaring
HL Falbaum
I know the LS4 has an optional bracket for ballast --allows pilots down to
about 100#, and the G102 as well.
Hartley Falbaum
L33: 121 lbs
Old February 1st 07, 04:29 AM posted to rec.aviation.soaring
Roy Clark, B6
it?
Dan
Phil Collin
Partner Manager
T: 0845 862 1 862
E:
W:www.voicehost.co.uk
I agree and would add - be sure you have the correct weight and
balance information.
For pilots of relatively light weight, this extra care can be
lifesaving.
Example:
NTSB Identification: SEA96FA186 .
The docket is stored in the Docket Management System (DMS). Please
contact Records Management Division
14 CFR Part 91: General Aviation
Accident occurred Saturday, August 10, 1996 in SHELTON, WA
Probable Cause Approval Date: 1/30/1998
Aircraft: Let L-13, registration: N90865
Injuries: 1 Fatal.
After receiving a glider certification on 7/24/96, the pilot (plt)
logged about 2.1 hrs in a Let L-13 glider, before flying it solo. The
initial solo was the accident flight (flt) on 8/10/96. On this flight,
the plt planned to be towed to traffic pattern altitude, then release
the glider, enter the traffic pattern, & land. Release occurred about
3 mi southwest of the airport at 1,850 ft. Airport elevation was 269
ft. Witnesses said the L-13 entered a right spin about 5 to 10 sec
after release & continued spinning until ground impact. To keep the
center-of-gravity (CG) from exceeding the aft limit, a placard had
been installed in the cockpit, indicating the minimum front seat solo
weight to be 150 lbs. The L-13's operating manual contained this &
other info based on the L-13's original weight & balance (W/B)
configuration. The plt weighed between 128 & 135 lbs, & a single 25 lb
ballast bag was found in the wreckage. However, after repainting &
modification with a non-standard tailwheel, the glider's revised W/B
data indicated the current minimum front seat solo weight was 181 lbs.
Based on this info (kept in the operator's maintenance shop), the
glider's C.G. was computed to be 1.4 inches behind the aft limit. The
plt's personal copy of the L-13 operating manual did not contain the
revised W/B data. Copies of the glider's operating manual were being
sold to renters without this info.
The National Transportation Safety Board determines the probable
cause(s) of this accident as follows:
failure of the operator to provide its pilots with information
essential for an accurate determination of the glider's weight and
balance, the resultant operation of the glider with a center-or-
gravity that exceeded the aft limit, and the pilot's inadvertent entry
into a stall/spin. Factors relating to the accident we an incorrect
placard concerning the glider's minimum front seat solo weight
limitation, and the pilot's lack of experience in the make and model
of aircraft.
Old February 1st 07, 04:39 AM posted to rec.aviation.soaring
BT
our LS4 has ballast added to the tail, the min cockpit weight is normally
154# but with the added tail ballast it is 171#, the nose ballast (up to 3
weights forward of the rudder pedals) is equivalent of adding 11# for each
weight to the seat or 33#, so 171-33=138# or.. 121# if the tail ballast was
removed.
BT
"HL Falbaum" wrote in message
Hartley Falbaum
L33: 121 lbs
Old February 1st 07, 10:27 AM posted to rec.aviation.soaring
Tom Gardner
it?
I guess that person is also small, so are there any examples of
adding
extra weight in the form of a "very heavy cushion" between the pilot
and the seat? Perhaps a very heavy cushion could be fashioned from
lead or rubber sheeting, and placed between the energy absorbing
cushion and the seat pan.
Old February 1st 07, 05:06 PM posted to rec.aviation.soaring
Maciek
PW-5 - 121 lbs
A friend of mine, who had similar problem, used to carry a little bag filled
with sand (made by her mother;-), which placed under her...you know where,
added some extra lbs (even 20 ). One thing you should do if you use this
solution is to make sure, that the sand never gets out into the cockpit - it
may cause seizing of some mechanisms and it can end badly. Better if you
raplace sand with some stones (less comfortable, but more safety)
Maciek
Old February 1st 07, 07:06 PM posted to rec.aviation.soaring
Michael Ash
it?
adding
We have some bags of lead shot and at least one lead plate that we use as
you describe for those front-seaters who are too far under the limit for
our available normal ballast to fix. It works well and, I'm told, is
perfectly comfortable if positioned properly.
I heard a frightening story about a kid who needed ballast for his first
solo in some sort of powered plane. They stuck a lead plate under him to
bring his weight up to the minimum. Sometime during the flight the plate
slid up, jamming the stick full forward. He completed several outside
loops before unjamming the stick, regaining control, and landing safely.
Obviously you should make sure this can't happen to you.
Michael Ash
Rogue Amoeba Software
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 08:32 PM
Bolkcom of the CRS against F/A-22 Henry J Cobb Military Aviation 20 March 8th 04 05:14 PM
RV-7a baggage area David Smith Home Built 32 December 15th 03 05:08 AM
Va: maneuvering speed ad nauseam Koopas Ly Piloting 14 November 29th 03 06:07 PM
