FAA MAY TAKE AWAY PANEL-MOUNT OPTION FOR PORTABLE GPS
Old February 2nd 07, 03:25 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Default FAA MAY TAKE AWAY PANEL-MOUNT OPTION FOR PORTABLE GPS
From AOPA
Think your portable GPS would work great mounted to your old Cessna 172's
instrument panel? If the FAA has its way, you won't be able to mount it. The
parts-panel dock and connective wiring-needed to mount your portable GPS
would either no longer be available or be too expensive to buy. The FAA's
proposal would make it illegal for manufacturers to produce a replacement or
modification part if they know (or should know) the part would end up
installed in a certified aircraft-that is unless they obtain production
approval from the agency. But that costs tens of thousands of dollars,
something many companies can't afford. While AOPA agrees production approval
is necessary for critical parts like connecting rods and cylinders, it isn't
needed for non-critical parts like a portable GPS panel dock or traffic
detector that enhance pilot safety. See AOPA Online.
Old February 3rd 07, 04:12 AM posted to rec.aviation.homebuilt
Roger[_4_]
On Fri, 2 Feb 2007 08:25:13 -0600, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote:
From AOPA
Anything panel mounted is already supposed to be certified.
That's why mine is clamped on the yoke.
www.rogerhalstead.com
Old February 5th 07, 11:21 PM posted to rec.aviation.homebuilt
RST Engineering
Please define certified.
Please cite sources.
"Roger" wrote in message
Old February 6th 07, 07:34 AM posted to rec.aviation.homebuilt
Roger[_4_]
On Mon, 5 Feb 2007 14:21:36 -0800, "RST Engineering"
It's what we were told at one of the seminars. Don't remember which
now. Anything bolted down was considered to need to be certified as
in radios. Stick it down with velcro as it was supposed to be OK.
If it didn't need to be certified I'd stick my 100 watt Yaesu in there
Panel mount IFR GPS for training ... Bud_of_yours Piloting 23 December 24th 06 07:38 PM
Softcomm panel mount intercom? Junk? [email protected] Owning 10 November 26th 05 07:46 AM
Panel mount for handheld Garmin GPSMap X96 series Brock Boss Owning 2 September 25th 05 02:26 AM
Need panel mount for Delcom Radio Mark Lenox Soaring 3 June 24th 05 04:31 AM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 04:33 PM
