Tuareg tows a 747 (strange one)
Old November 25th 06, 05:56 AM posted to alt.binaries.pictures.aviation
Mike[_2_]
Default Tuareg tows a 747 (strange one)
While this story is actually a PR story by VW about a VQ Tuareg towing a
747, look at the photos - pay attention to the engines
http://www.autoblog.com/2006/11/22/t...di-tows-a-747/
The plane used for the stunt was a decommissioned Boeing 747-200 that weighs
155 tons. VW had initially calculated the Touareg could successfully pull
200 tons, and had even done a dry run with a 190-ton Boeing 747-400.
Unfortunately, the only plane that could be acquired for the PR stunt was
this one that is usually used as a giant prop in films.
Don't quite think this engine configuration is standard, and presumably it
isn't airworthy..
Old November 25th 06, 09:48 AM posted to alt.binaries.pictures.aviation
Cumulus Glider Rescue
This is at Dunsfold in Surrey. UK and was recently used in the james Bond
film i believe, not airworthy.
MC
"Mike" wrote in message
. com...
weighs 155 tons. VW had initially calculated the Touareg could
successfully pull 200 tons, and had even done a dry run with a 190-ton
Boeing 747-400. Unfortunately, the only plane that could be acquired for
the PR stunt was this one that is usually used as a giant prop in films.
isn't airworthy..
Old November 25th 06, 10:14 AM posted to alt.binaries.pictures.aviation
Markus Baur
hi ..
isn't airworthy..
looking closely at
http://www.blogsmithmedia.com/www.au...6-b-vw_450.jpg
is the lift inboard engine truly doublepodded (two engines on one
pylon)? and what is that strange white thing behind that engine?
does anyone have more pics . ?
servus
markus
Old November 25th 06, 11:05 AM posted to alt.binaries.pictures.aviation
The Raven
"Markus Baur" wrote in message
hi ..
it isn't airworthy..
looking closely at
is the lift inboard engine truly doublepodded (two engines on one pylon)?
Look at the last pic which shows the starboard wing. Yep, dual engines on
inboard pylons with dummy somethings on the outboard pylons.
They said it was a movie prop, so I'd be expecting to see a move with dual
inboard engines with long range drop tanks or EW pods....
My guess the pods outboard are to fill the outboard pods with something
critical to the plot or justifying some major FX later in the movie.
The Raven
http://www.80scartoons.co.uk/batfinkquote.mp3
** Now I will bring chaos to the world!
Old November 25th 06, 07:12 PM posted to alt.binaries.pictures.aviation
Maple1
servus
markus
ID:	927  Click image for larger version
ID:	928  Click image for larger version
ID:	929  Click image for larger version
Old November 25th 06, 07:14 PM posted to alt.binaries.pictures.aviation
Maple1
Also more here
http://forum.keypublishing.co.uk/sho...d.php?p=961055
Dont you guys know how to use Google?
Just type in the reg# and you will find a whole lot about it.
N9747P
Old November 25th 06, 08:59 PM posted to alt.binaries.pictures.aviation
Ron
"Maple1" wrote in message
news:BK%9h.371780$R63.205624@pd7urf1no...
Also more here
N9747P
I went for the registration at Airliners.net and came up with
http://www.airliners.net/search/phot...eywords=N9747P
Something completely different!
Ron
Old November 25th 06, 09:30 PM posted to alt.binaries.pictures.aviation
Markus Baur
Also more here
N9747P
Ron
anyhow .. the secret is revealed once you watch the newest bond movie
... 8-)
servus
markus
Old November 26th 06, 06:54 AM posted to alt.binaries.pictures.aviation
Toolpusher
Markus Baur wrote in
Also more here
N9747P
Ron
.. 8-)
servus
markus
Which is well worth seeing, I thoroughly enjoyed it, and that's the first
time I've made the effort to see a Bond film in a Cinema since Moonraker.
USA: Places to get tows in ID, OR and WA [email protected] Soaring 7 January 26th 06 05:29 PM
Tows in Southern UT and NV glider guider Soaring 3 October 26th 04 12:21 AM
Tows available near Tucson? Janus2k Soaring 2 May 6th 04 07:28 AM
We have done auto tows in the past few years Joe Allbritten Soaring 2 March 5th 04 04:45 AM
CG hook on aero tows?? Ted Wagner Soaring 130 January 13th 04 12:04 AM
