competition finishes
Old February 12th 07, 10:33 PM posted to rec.aviation.soaring
Derek Ruddock
Default competition finishes
All the recent heated debate on competition finishes,
and how to change the rules to prevent beat ups, has
focussed on a minimum height finish, which also has
its problems.
Why not approach the problem from a different direction,
and have a rule that states a maximum speed within
a radius of the airfield, for example 70 knots within
2 miles or 5km?
This will not prevent competitors from converting their
margin to speed, but due to the distance that remains
to be covered, will ensure that it takes place at a
reasonable height.
Note I use the 70 knot/2 mile figure as an example
only. The numbers can obviously be changed as appropriate.
Old February 13th 07, 12:26 AM posted to rec.aviation.soaring
Derek Copeland
So how are you going to police this? Radar guns? Measuring
GPS logger plots after the event? Would it be ground
speed or airspeed, and if the latter, how would you
allow for wind speed and gusts? All sounds a bit impractical
to me!
Derek Copeland
its problems.
2 miles or 5km?
reasonable height.
Old February 13th 07, 02:54 AM posted to rec.aviation.soaring
Mal[_3_]
More like laughable considering I do not ever recall Derek winning a comp
day!
Our Australian comp rules and CAR's have accommodation for low finishes and
the GFA now requires a log book endorsement to do so.
http://www.nswgc2006.com.au/doc/NSW_...ules_Nov06.pdf
http://www.gfa.org.au/Docs/sport/nswrules.pdf
Old February 13th 07, 04:26 AM posted to rec.aviation.soaring
Tuno
A logbook endorsement sounds logical. Who in Australia are authorized
to do them?
I remember when I started racing a few years ago having to figure it
out for myself. Of course, I picked the brains of the pilots I was
racing with, but outside of that, the topic was not addressed (in a
how-to fashion) in any of the stack of racing-related reading
materials I assembled, which I found curious. It seemed to be a
sanctioned activity, after all.
I've always viewed fast, low finishes them as something of a penalty
(speaking in a racing context, of course). If you have the energy to
spend the last few miles of your last leg in a highly inefficient part
of the polar, it means you accumulated too much energy before starting
your final glide, and you lose more from that than you gain with a low
finish.
But they sure are fun to watch. I will never forget the sight of a 15M
glass slipper doing a worm burner finish at Seminole Lakes in November
2003 when I was a pre-solo student stick. He went by at mach 2, a
meter off the grass, from one length of the field to the other, and I
never heard a whisper, and he was maybe 100 meters away. I was amazed,
and I was hooked.
~ted/2NO
Old February 13th 07, 09:48 AM posted to rec.aviation.soaring
Mal[_3_]
16. FINISH PROCEDU The finish line shall be the perimeter of a circle of
1.5km in radius
centred on the Aerodrome finish co-ordinates. Finishes are to be in
accordance with
CAO 95.4 (ie not below 500 feet AGL) until within 5 kilometres of the finish
line and must clear all
obstacles by at least 50 feet. Pilots should finish from the direction of
the last turnpoint or control
point.
http://www.gfa.org.au/ops/endorsement.php
http://www.casa.gov.au/download/orders/cao95/9504.pdf
Old February 13th 07, 01:34 PM posted to rec.aviation.soaring
Andy[_1_]
I read the linked documents but could not find a reference to how a
pilot qualifies for the low level enforsement. Does it require
specific training, or is it sufficient to have been doing it for years
without mishap.
Andy
Old February 13th 07, 01:45 PM posted to rec.aviation.soaring
Andy[_1_]
finish.
Sure - it's more efficient to finish at your interthermal speed but
the penalty for finding yourself too low and topping off in a garbage
thermal is far worse that keeping a safety margin and burning it at
the end. How much safety margin may depend on pilot experience, the
terrain close to the airport, and the expectation of lift/sink.
In USA it was common to finish at 50ft min through the line and then
pull up and fly a circuit to land. It seems other countries are flying
a worm burner to a straight in landing. That seems to give less
options if the runway is congested.
Andy
Old February 13th 07, 02:00 PM posted to rec.aviation.soaring
Mal[_3_]
"Andy" wrote in message
without mishap.
Andy
http://www.gfa.org.au/Docs/ops/opregs.pdf links to the right have the info.
Specific training or demonstration would qualify as long as the instructor
was certified to do it.
GP finishes bagmaker Soaring 0 May 25th 06 01:11 AM
Tanker Competition On john smith Piloting 0 April 16th 06 04:06 AM
Satellite wx competition john smith Piloting 0 February 10th 06 03:03 AM
FAA regulates competition Robert M. Gary Piloting 31 December 14th 05 04:34 AM
Competition I.D. Ray Lovinggood Soaring 22 December 17th 03 01:22 AM
