SSA Convention Presentation...was this as good as it sounds?
Old February 25th 07, 10:56 PM posted to rec.aviation.soaring
Stewart Kissel
Default SSA Convention Presentation...was this as good as it sounds?
http://sinhatech.com/
Old February 26th 07, 07:26 PM posted to rec.aviation.soaring
On Feb 25, 3:56 pm, Stewart Kissel
yea it was pretty interesting. Dick Johnson seemed convinced that
they worked, and thats good enough to convince me that they work.
Old February 26th 07, 08:23 PM posted to rec.aviation.soaring
Bill Daniels
A lot of things 'work' but, in the end, prove impractical. For example,
suction boundary layer control works spectacularly using tiny amounts of
power for the suction fans but the whole thing quickly gets plugged up with
dirt and is a nightmare to clean.
I don't doubt that Dr. Sinha's device works essentially as he says but the
membrane seems very fragile. If it is as humidity sensitive as it appears,
how would you wash the glider? What precautions would be needed to fill
ballast tanks?
Then there is the question whether the same result can be achieved less
intrusively. For example, could a flow be 'deturbulated' with ultrasonic
transducers below the wing skins.
(http://www.freepatentsonline.com/4741498.html) (Hmm, if you get 100:1 can
you drive dogs nuts in three states?)
None of this prevents me from hoping that it works it all out. If it does,
I'll be standing in line to get it.
Bill Daniels
Old February 27th 07, 05:28 AM posted to rec.aviation.soaring
Shawn[_3_]
ballast tanks?
If it can do for your Nimbus what he claims it does for a Cirrus, that
would be something :-)
Same/similar airfoil?
Shawn
Anyone have a good Ridge Training presentation or book Papa3 Soaring 1 June 26th 06 03:25 PM
Sounds like a dragonfly PitCock Home Built 0 March 8th 05 07:39 AM
PCC Presentation Jim Vincent Soaring 18 April 9th 04 07:07 AM
SOUNDS OF seaplanes [email protected] General Aviation 9 January 26th 04 12:20 AM
FS2002 sounds help Robert Kesik Simulators 0 July 2nd 03 11:17 AM
