How to split a tracklog of several flights for OLC?
Old April 4th 07, 12:29 PM posted to rec.aviation.soaring
db
Default How to split a tracklog of several flights for OLC?
I'm using garmin 96, g7towin for track download, and SeeYou software.
Do I have to split tracklog of several consecutive flights if I want to
upload only the best one to the OLC, or I can upload the whole tracklog?!
What will happen then?
Well, garmin devices have a strange feature - if you SAVE a tracklog after
each flight, you lose all altitude data. You have to download it as an
active log to preserve all data.
When using g7towin, I tried to separate the flights using "start new
segment" option and saving it as .g7t or.plt file (no option to save it as
..igc first) and then converting them to .igc file (save as .igc file
option), but then I lose securitiy G line at the end of each track.
Well, do you have any idea how to that?
Old April 4th 07, 03:56 PM posted to rec.aviation.soaring
Tuno
Unless the 2007 OLC software has changed a lot, you can provide your
log file as is, and tell the system what to use for start and end of
flight times.
Old April 5th 07, 10:36 AM posted to rec.aviation.soaring
db
flight times.
Excellent! Thanx!
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 11:43 AM
Garmin 340 Audio Panel Split Com O. Sami Saydjari Owning 9 January 27th 04 09:55 PM
Anyone want to split room for SSA Convention Jeff Landfield Soaring 1 January 27th 04 06:05 PM
Rogue's Gallery Split 3 Ways! Jay Honeck Piloting 8 December 22nd 03 07:53 PM
Split Cycle Engine Technology Canzie Rotorcraft 1 October 24th 03 03:34 PM
