Ivo prop
Old April 5th 07, 09:59 AM posted to rec.aviation.homebuilt
Philippe Vessaire
Default Ivo prop
Hello,
Any comment about this prop.
Will I be happy with an O200 on my Minicab (110kts expected)?
thanks
Minicab F-PRAZ
Philippe Vessaire Ò¿Ó¬
Old April 5th 07, 04:41 PM posted to rec.aviation.homebuilt
Default Ivo prop
On Apr 5, 1:59Â*am, Philippe Vessaire wrote:
Hello,
Â* Â*Any comment about this prop.
Will I be happy with an O200 Â*on my Minicab (110kts expected)?
thanks
Minicab F-PRAZ
Â* Â* Philippe Vessaire Â*Ò¿Ó¬
The experience we had with an IVO wasn't good. It was on a
Subaru using a redrive, so the input was smoother than a direct-drive
would be, but still experience vibration caused by the blades shifting
between the clamping plates. There have been several reports of Ivos
throwing blades, and when you see how they're made it's easy to
understand. The blades are mostly a high-density foam with a really
thin skin of carbon fiber, and they're retained by means of two bolts
through aluminum bushings in each blade root. There's enough slop that
the blade can move tangentially in the hub, throwing the chordwise
balance off.
The Ivo pulled really well. Better than the Warp Drive we
replaced it with.
Dan
Old April 5th 07, 08:31 PM posted to rec.aviation.homebuilt
Default Ivo prop
I have 140 hours on IVO in my homebuilt with 200hp Franklin. The prop
plates are knurled and I have never seen any blade shifting - make
sure to follow IVO instructions and for proper bolt torque and check
the torque once in a while. I have some vibration but not excessive.
There is an advantage to those plastic blades - had a near gear up
landing and the blades broke "nicely" - no damage to the driveshaft
(had it magnafluxed). The main advantage with my inflight adjustable
IVO is good takeoff performance (I need it with my fast canard) and
decent cruise. Some day when I have excess money I would like to try a
Catto or similar wood prop for performance comparison.
I have heard that IVO does not tolerate Lyc and other four bangers
especially big ones. The torsional pulses are too great for the
blades. A smooth six or auto adaption is not such problem. Ivo will
not sell you a prop for a Lyc four banger.
SQ2000 canard http://www.abri.com/sq2000
On Apr 5, 2:59 am, Philippe Vessaire wrote:
Hello,
thanks
Minicab F-PRAZ
Old April 12th 07, 09:12 PM posted to rec.aviation.homebuilt
Default Ivo prop
The prop we had was an earlier mode; no knurling on the
plates. No matter how snug we got the bolts we still had some
fretting. And because the bolts have clearance in the blade bushings,
you can't get the blades aligned axactly opposite each other with any
accuract, and the chordwise balance is off. You could pay for dynamic
balancing but it would be off again the next time the prop was apart.
Which goes to show how weak they are. I'd rather find a prop
with a lot more margin and would settle for a fixed-pitch wooden prop
before I'd use an IVO again. They did have a "Magnum" version that was
supposed to be OK for the direct-drive applications, but maybe they've
taken it out of those applications.
I've often thought it would be interesting to adapt a larger
helicopter tail rotor to a homebuilt propeller application.
Mechanical, manual pitch control that has fewer gyroscopic issues,
with its teetering action and automatic pitch differentiation to keep
it aligned with the shaft. I think I'd want to try it on an airboat
for a while, first. There are almost always unforseen issues. Maybe
someone has already tried it?
Dan
Old April 12th 07, 11:33 PM posted to rec.aviation.homebuilt
Dan[_2_]
Default Ivo prop
Dan
Tail rotors are symmetrical airfoils. I thought about it myself
when I was working on helicopters. I suppose you could do it, but I
don't think it would be very efficient. If you want to play with some
blades they show up on e-bay occasionally.
Dan, U.S. Air Force, retired
Old May 29th 07, 08:40 PM posted to rec.aviation.homebuilt
Default Ivo prop - balancing
On Apr 12, 2:12 pm, wrote:
...... and the chordwise balance is off. You could pay for dynamic
Not exactly true with knurled plates - the advice is to to reinstall
the blades in the same "knurl position" as when taken off.
This brings to mind the "balancing disk" (from http://www.balancemasters.com/ultralights.html
) I have installed. It seems to work. There is notable more vibration
when I take it off. You can see a photo at http://www.abri.com/sq2000/balancer.jpg
(hit reload if you get a permission error) Is anybody else using one
of these?
Old May 30th 07, 01:41 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
of these?
I had 4 of 'em on my 53 Dodge Coronet wagon. One on each wheel. Never
had a balance problem, but the Kelly's were pretty well balanced to
start with (seldom had to use more than a 1/4 oz weight to ballance a
bias ply first run Kelly.
Posted via a free Usenet account from http://www.teranews.com
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 11:18 PM
Need A40 Prop Larry Restoration 0 November 17th 04 01:13 PM
static prop hub for T-6 prop ralph peterson Aviation Marketplace 0 January 25th 04 05:06 AM
Hydraulic CS prop converting to Adjustable prop? Scott VanderVeen Home Built 0 December 5th 03 06:54 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 08:45 PM
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
Copyright ©2004-2026 AviationBanter.
