Where old planes go to die (eventually)
Old May 11th 07, 04:14 PM posted to rec.aviation.piloting
Kingfish
Default Where old planes go to die (eventually)
I spent a week in the Caribbean in early April flying charters out of
San Juan. Our planes were stuffed away out of sight on apron 7 at SJU.
Interesting place there - we shared ramp space with a grounded DC-3, a
pair of Convair 440s, a few freight 1900s & Metros, a hunk of 727
fuselage, and a derelict Mallard & PBY. San Juan is home to Four Star
- a freight company that flies DC-3s (some with the Baseler turboprop
conversion) which is amazing to consider as those planes are 50+ years
old and still in revenue service. Watching the Convairs' engines
start, it became obvious why there's no mosquito problem on the ramp -
you've *never* seen so much smoke from a plane that wasn't on fire...
(note to Dudley H: Did those things puke oil when they were new??) It
kinda added to the outback vibe of the place - where else but the
Caribbean or South America do you see these old props still flying
people/freight? I was hoping to see a DC-6 or -7 but no luck.
Old May 11th 07, 07:05 PM posted to rec.aviation.piloting
Robert M. Gary
They don't die, they return to the earth from which they came.
Old May 13th 07, 08:18 PM posted to rec.aviation.piloting
Don Hammer
Round engines are dry sump with a separate oil tank. After shutdown,
the oil left in the engine ends up in the bottom cylinder(s) whereby
it will eventually seep through the gaps in the rings.
Most of them require rotating a few blades prior to turning on the
mags to make sure there is no hydraulic lock ( could bend a rod) and
to spit any oil out the exhaust. It's the same reason you see the guys
pulling them through by hand in old movies.
When they light off, they throw oil mist and smoke out the pipes. You
don't want your plane close behind one of them or you'll need a wash
job.
New or old they all do it.
Old May 14th 07, 05:40 AM posted to rec.aviation.piloting
Luke Skywalker
Go to KHUM LA...there is a 6 there. They use it for oil dispersal and
(hard to believe) mosquito spraying.
Robert
Planes On Poles, pt 3 - mig 15.jpg (1/1) Mitchell Holman Aviation Photos 0 January 19th 07 04:32 AM
I eat old planes !!!!!!!!!!! Bruno Beam Restoration 0 December 20th 04 01:51 AM
Underwater planes are the most dangerous planes !!!!! Bruno Beam Naval Aviation 0 December 14th 04 05:01 AM
Old Planes...Where Are They Now Charles Talleyrand Military Aviation 15 June 24th 04 11:35 AM
new planes Randall Robertson Simulators 0 December 21st 03 09:54 PM
