Getting SUA from DAFIF files
Old May 24th 07, 02:12 AM posted to rec.aviation.soaring
Tuno
Default Getting SUA from DAFIF files
If anyone can point me to resources on the following SUA topics I
would be most gr8ful:
1) DAFIF file format, specifically, descriptions of the fields (and
their relationships) in the BDRY.TXT, BDRY_PAR.TXT, SUAS.TXT, and
SUAS_PAR.TXT files. (These are the four files used by Carl Ekdahl's
"airspace" program.)
2) Any description of how the above files are used to create SUA
files. (Besides what comes with Carl's software.)
3) The SUA format that is the output of Carl's program. Specifically,
the syntax that is processed by GNII to instantiate airspace.
10q/tuno
Old May 25th 07, 09:15 AM posted to rec.aviation.soaring
Tuno
Thanks Tim. I've followed the format on that web page to the best of
my ability, but my modest home-made SUA file is making my GNII very
unhappy!
Old May 25th 07, 01:50 PM posted to rec.aviation.soaring
Paul Remde
Hi Tim,
You can export SUA files that work great with GN II in about 2 minutes using
StrePla. I'd be glad to make you one. What area do you want it to cover?
Or you can download the demo version of StrePla and do it yourself. I use
it often for that function.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Tuno" wrote in message
unhappy!
Old May 25th 07, 05:09 PM posted to rec.aviation.soaring
Tuno
Thanks Paul, but where does Strepla get its data? I want the current
USFIF to be the source.
I've pretty much finished writing a tool to do what I want, and the
results look great when loaded in SeeYou, but something about it makes
GNII unhappy. I've sent the file to the Powers that Be to see if they
can figger it out ...
-ted/2NO
DAFIF fallout? [email protected] General Aviation 2 October 24th 06 10:33 PM
Solution to DAFIF data going away? Paul Tomblin Piloting 1 June 5th 05 01:36 PM
DAFIF data Paul Tomblin Piloting 1 January 2nd 05 11:13 PM
DAFIF going away? Paul Tomblin Piloting 2 August 10th 04 04:30 PM
Non-USA DAFIF files - Where to find Michael Soaring 1 March 29th 04 07:47 PM
