Coordinated turns without rudder, and autopilots
Old May 28th 07, 02:44 AM posted to rec.aviation.piloting
Mxsmanic
Default Coordinated turns without rudder, and autopilots
How do autopilots make coordinated turns even when they cannot control the
rudder?
Old May 28th 07, 03:34 AM posted to rec.aviation.piloting
Dan[_1_]
rudder?
If they don't control the rudder, they do not make coordinated turns!
--Dan
Old May 28th 07, 05:10 AM posted to rec.aviation.piloting
John Theune
rudder?
What makes you think they do not control the rudder?
Old May 28th 07, 11:52 AM posted to rec.aviation.piloting
gpaleo
Ο "John Theune" έγραψε στο μήνυμα
news:KKr6i.8843$zN5.5464@trndny05...
rudder?
Mine (KFC-150) does not.
Old May 28th 07, 02:30 PM posted to rec.aviation.piloting
Bob Moore
the rudder?
Swept wing and some straight wing aircraft have independent Yaw Damper(s)
that control the rudder(s). Their primary function is to control (prevent)
dutch roll. They operate with the autopilot on or off.
From Wikipedia, the free encyclopedia
A yaw damper is a device used on many aircraft (usually jets and
turboprops) to damp (reduce) the rolling and yawing oscillations due to
Dutch roll mode[1]. It involves yaw rate sensors and a processor that
provides a signal to an actuator connected to the rudder. The use of the
yaw damper helps to provide a better ride for passengers, and on some
aircraft is a required piece of equipment to ensure that the aircraft
stability remains within certification values.
The term is often mis-pronounced as a "yaw dampener".
Bob Moore
Old May 28th 07, 03:11 PM posted to rec.aviation.piloting
Ron Natalie
rudder?
--Dan
Boy we have the blind leading the blind here.
The whole point of that big vertical slab of metal sticking out of the
ass-end of your airplane is to provide a natural tendency for the
aircraft to fly coordinated. The pedals are just there for the
outlying conditions (low speed, high AOA for example) and fine
adjustment.
Old May 28th 07, 03:58 PM posted to rec.aviation.piloting
Matt Whiting
control the
rudder?
--Dan
adjustment.
And now we have the three blind mice...
Old May 28th 07, 05:59 PM posted to rec.aviation.piloting
Luke Skywalker
rudder?
--Dan
adjustment.
Ron...
oh my goodness...get some time with a good book on the subject and
then a CFI.
Robert
Old May 28th 07, 07:26 PM posted to rec.aviation.piloting
Andrew Sarangan
rudder?
--Dan
adjustment.
Ron...
then a CFI.
Robert- Hide quoted text -
Ron is correct. The vertical fin makes the airplane weather-vane into
the wind, and that's what co-ordination is all about. The rudder is
there only to help the vertical stab do this job.
A perfect airplane will not need rudder.
Old May 28th 07, 09:12 PM posted to rec.aviation.piloting
Dan[_1_]
rudder?
--Dan
adjustment.
Ron...
then a CFI.
A perfect airplane will not need rudder.- Hide quoted text -
- Show quoted text -
So where is this perfect airplane? I don't know about you, but I need
the rudder pedals to fly the aircraft.
--Dan
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 05:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 11:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 07:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 07:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 09:46 PM
