TTF (trying to flog) Sperry SP20 gyropilot amplifier assembly. C130
Old August 8th 03, 10:23 PM
tongaloa
Default TTF (trying to flog) Sperry SP20 gyropilot amplifier assembly. C130
put it on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...m=2426570 431
but it's either...
uninteresting
or priced wrong
what do you think
scrap metal/rob the parts/or something that someone could use...
tnx
-t
Old August 9th 03, 12:55 AM
Tarver Engineering
"tongaloa" wrote in message
put it on ebay
but it's either...
uninteresting
or priced wrong
what do you think
FAA TSO 10b is for an altimeter, so I'll go with the ad being bull****.
Old August 9th 03, 01:59 AM
tongaloa
Thanks for comments.
I pulled info off nomenclature plate.
Looked up pn with google and it crossed to the NIIN
listed as amplifier. It does have a port so you may be right.
35 lb seems a bit much for 'just an altimeter'...
Will cannibalize if that's all it turns out to be. Can use the
sensor for a project...
-Bob
put it on ebay
but it's either...
uninteresting
or priced wrong
what do you think
Old August 9th 03, 02:02 AM
tongaloa
My goof.
It's FAA TSO 9b
Right there on the plate.
Don't know how, transcribed as a 10...
So what do you think?
Rob the parts or look for a home?
Old August 9th 03, 06:06 AM
B2431
I have repaired my share of those. You are better off converting a blind
encoder. The amp for auction is 1950 - 1960s technology with about a dozen
tubes.
For all usable parts I'd go no higher than $40 or $50 since it is useless as
AFCS in anything other than the system it was intended for.
Dan, U. S. Air Force, retired
Subject: TTF (trying to flog) Sperry SP20 gyropilot amplifier assembly.
Date: 8/8/2003 6:59 PM Central Daylight Time
Message-id:
-Bob
Kinda OT but... Trying to flog a Sperry SP 20 autopilot servo ampfor C130... tongaloa Home Built 0 August 8th 03 08:45 PM
Sperry SP20 Gyropilot amplifier assembly tongaloa Aviation Marketplace 0 August 8th 03 08:38 PM
