Airspeed Indicator problems
Old June 18th 07, 02:24 AM posted to rec.aviation.soaring
Default Airspeed Indicator problems
The original Schweizer airspeed indicator in my glider sticks.
Once on the ground I blew into the pitot and the indicator shows an
airspeed but then it takes 10 seconds to slowly go back down to 0.
On the back of the instrument there are 2 vertical ports.
I disconnected and blew through the top tube which runs to the static
ports. Blew just fine, no blockage.
The pitot line runs to the bottom port on the back of the instrument
but not direclty. It has a tee that routes it off to another
instrument also. I would have thought that the pitot should have an
uniterupted tube going directly to the airspeed indicator.
The diagram in the opertors manual shows a dedicated line going from
the pitot to the top port on the back of the instrument
and the static line going the the bottom port. Just opposite of my
particular installation.
Any advice would be appreciated.
Stan
Old June 18th 07, 04:42 PM posted to rec.aviation.soaring
Stan: First advice: STOP BLOWING IN THE ASI! That's the best way
there is to destroy it, which you might already have done. I've seen
people walk up to a pitot tube and put their mouth to it, and I cringe
at the thought of what they're doing to the internal workings. If you
disconnect the plumbing from the instruments you can check it's
continuity by drawing a slight vacuum on it and seeing if it holds.
I've seen plastic tubing chewed through by mice, and worse yet, I've
seen instruments incorrectly plumbed by someone who was "testing the
system." If neither of these is the problem you probably need to send
the instrument to a qualified shop. Fred
Old June 18th 07, 06:56 PM posted to rec.aviation.soaring
chipsoars
If it is an old instrument, it could be an accumulation of dirt,
especially if flown from turf or a dusty area. Repair or replace the
instrurment and check out the plumbing as Fred suggests.
Also, plastic tubing degrades over time and can become a problem with
leaks.
Chip F.
Old June 18th 07, 08:23 PM posted to rec.aviation.soaring
Bill Daniels
If you are interested, I have an old Schweizer airspeed without markings
that has been on a shelf since about 1965. Make me an offer.
Bill Daniels
"chipsoars" wrote in message
leaks.
Chip F.
Old June 18th 07, 11:02 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Apart from the possibility of moisture ingress, the resulting pressure
is likely to be too high and can easily wreck the ASI.
After I've had the panel out of my Standard Libelle, which has the pitot
and TE probe on the fin and hence a lot of plastic tubing to leak, I use
the following simple check procedures:
- start with normal or cool air temperature
- place my thumb over the end of the pitot.
- with thumb remaining firmly in place I close my hand round the pitot
tube and wait.
- after 5 to 10 seconds the ASI comes off its stop and indicates
about 10 to 15 kts
- the reading remains stable as long as I care to retain my grip on
the pitot.
- the ASI returns to zero when I let go the pitot.
This shows that the ASI is in working order and that there are no leaks
between pitot and ASI. Of course it says nothing about the ASI
calibration but that gets checked during the annual C of A.
The only blowing I do is a trick shown me by an old hand. Turn the vario
on and the volume fully up. Hold your hands parallel to each other,
fingers together and bent slightly backward, on either side of the TE
probe and with your palms about 25mm (1 inch) apart. Blow hard between
your hands with your mouth about 100-150mm (4-6 inches) away from the
heels of your hands. If the system is operating correctly you'll hear
the vario signal a climb for 2-3 seconds and then go back to zero.
If both tests work OK I can be pretty sure that the pneumatic quick
connect at the panel was sealed correctly when I put the panel back in.
HTH
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 19th 07, 03:06 AM posted to rec.aviation.soaring
HL Falbaum
Stan
I agree with the other posters---send it in for cleaning, and calibration.
The tee is probably to a netto cappilliary, or possibly to a hidden
diaphragm TE compensator.
A 10 cc medical syringe is a good "air pump" for testing systems.
Hartley Falbaum
Old June 19th 07, 03:33 AM posted to rec.aviation.soaring
Ray Lovinggood
And then, there can be problems with sending instruments
in for a rebuild.
First, it was my altimeter. Off it went to a repair
shop in Kansas and came back with the glass cracked.
The crack went right to one of the screws. Damn.
Turn right around and send it back for 'warranty'
service. It has worked just fine since and that was
maybe three years ago.
Second, my airspeed indicator had a leak. I sent it
in to another shop in Kansas and authorized a check-up.
Turns out they tore it down and found it pretty much
all worn out and were in the process of starting to
totally rebuild it. Without my authorization. It
was going to cost around US$450. I told them to stop
and just send the instrument back to me. So, I bought
a new Winter airspeed indicator from Tim Mara at Wings
and Wheels for less than the rebuilt one would have
cost me.
I was hoping the old airspeed would just need a new
O-ring and a face cleaning.
Oh well.
Ray Lovinggood
Carrboro, North Carolina, USA
PS: The fairly new instruments didn't keep me from
landing out on Sunday
sticks.
of the instrument
to another
should have an
Stan
and calibration.
to a hidden
A 10 cc medical syringe is a good 'air pump' for testing
systems.
Hartley Falbaum
Airspeed Indicator Accuracy Tolerance O. Sami Saydjari Instrument Flight Rules 11 January 26th 06 01:48 AM
verifying airspeed indicator Heino & Deanne Weisberg Home Built 11 October 22nd 05 08:36 PM
Need glider airspeed indicator [email protected] Soaring 1 June 21st 05 10:57 PM
Inaccurate airspeed indicator Wyatt Emmerich Instrument Flight Rules 20 April 20th 04 01:08 AM
Tow plane airspeed vs. glider being towed airspeed? MHende6388 Soaring 2 September 28th 03 10:35 AM
