It doesn't fly, BUT...
Old June 19th 07, 10:12 PM posted to rec.aviation.homebuilt
Bart[_2_]
Default It doesn't fly, BUT...
I hope I'm not intruding here, but I'm building a car with a plywood
monocoque chassis bonded to fiberglass body panels. It's not as
bizarre as it may sound: the chassis design is based partly on that of
the Marcos GT, which used exactly that model of construction. The
chassis designer was Frank Costin (the "cos" of Marcos), who had done
a great deal of the design work on the deHavilland Mosquito, the
British plywood monocoque WWII fighter-bomber. As I'm sure you
aircraft folk know, a plywood monocoque has exceptional torsional
rigidity for its weight.
The car I'm building is open, so the rigidity loss inevitable with an
open cockpit will be largely restored by the use of deep, boxed side-
sills, fore- and aft-bulkheads, and a deep, chassis-long central boxed
spine, much like the Lotus Élan.
I'm looking for advice on bonding and bond-strengthening plywood box
structures (Marcos, for example, used spruce reinforcements at all
joints), and what thickness and kind of ply (Marcos used marine).
Any suggestions (besides the obvious!) greatly appreciated...
Bart Brown
Old June 19th 07, 11:06 PM posted to rec.aviation.homebuilt
Anthony W
Bart Brown
I don't have any suggestions but if you make a web page showing your
progress I'd sure like a link so I could follow your work.
Tony
Old June 20th 07, 02:10 AM posted to rec.aviation.homebuilt
Alan Baker
In article . com,
Bart Brown
What Anthony said...
Alan Baker
Vancouver, British Columbia
"If you raise the ceiling four feet, move the fireplace from that wall
to that wall, you'll still only get the full stereophonic effect if you
sit in the bottom of that cupboard."
Old June 20th 07, 03:41 AM posted to rec.aviation.homebuilt
cavelamb himself
Bart Brown
Google for "Stitch and Glue" and "Stitch and Tape" style boat
construction.
Richard
Old June 20th 07, 12:23 PM posted to rec.aviation.homebuilt
George
When I built my airplane I used plywood for many bulkheads about 14
years ago.
I got a good booklet on wooden boat building written by West Systems
Epoxy.
The epoxy is sold by West Marine nationally.
Here is an online link:
http://www.westsystem.com/webpages/userinfo/manual/
Good luck,
Old June 20th 07, 03:07 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
years ago.
Epoxy.
Good luck,
So a car builder came to airplane builders for help and he get's sent to a
book for boat builders.
Ain't the internet great.
Old June 20th 07, 03:29 PM posted to rec.aviation.homebuilt
Denny
Gougeon brothers book on WEST system will help..
Also, look up the airplane FALCO which is a wood monocoque...
Google under the terms monocoque + wood + epoxy for other references
In addition searches for carbon fiber, graphite, composite, etc. will
bring up more obscure references...
denny
Old June 20th 07, 09:39 PM posted to rec.aviation.homebuilt
Peter Dohm
"Bart" wrote in message
Bart Brown
Actually, a number of aircraft have been designed with boxed spars, but I
don't know of any that might help with the tie-in between the boxed side
sills, or the central box structure, and the fore and aft bulkheads.
Regrettably, my woodworking knowledge is in the home-handyman range, so I
can only suggest looking for a treatise on the construction of the original
Marcos cars. Your side and center sections will be no more than 25% of the
height of the original car, so the tie-ins will probably need to be at least
4 times as strong. If that won't work, you may need to consider a different
material, such as fiberglass or riveted aluminum.
BTW, was Frank Costin the same person who was part of Cosworth?
Peter
Old June 20th 07, 11:52 PM posted to rec.aviation.homebuilt
Alan Baker
Bart Brown
Peter
He was the brother of Cosworth co-founder *Mike* Costin. Cosworth was
founded by Mike Costin and Keith Duckworth.
Alan Baker
