Brass tail wheel
Old July 4th 07, 04:32 PM
Solo Solo is offline
Junior Member
First recorded activity by AviationBanter: Oct 2006
Default Brass tail wheel
I am looking for a brass tail wheel to shift the CG of my PIK-20B back.
I have seen the web sites of DG and AMS and they mention this type of wheel but cite no source.
Is there a source for such a wheel in Canada or the USA?
If not, where can I get one?
Old July 4th 07, 05:21 PM posted to rec.aviation.soaring
They cite no source since the source is themselves. I have no idea if
a brass tail wheel from a DG would fit a pik. I had a brass tailwheel
from a DG-80x machined (hub narrowed slightly) to fit my DG-303. It
was easier to buy the DG-80x part from Pacific Aero. Did a great job
moving the CG for Acro, kind of academic post wing spar TN
restrictions.
Darryl
Solo
Old July 4th 07, 05:43 PM posted to rec.aviation.soaring
Shawn[_3_]
Pacific AeroSport http://www.pacificaerosport.com/dgls.htm
Our club just bought one for its 505. Lead is cheaper :-)
Shawn
Old July 5th 07, 01:14 AM posted to rec.aviation.soaring
Ken Kochanski (KK)
Some of the guys in my club had the tail wheel filled with a urethane
compound (the same stuff they use in tractor tires). It added a lot of
weight, but was still squishy enough to provide some cushioning ---
and no more flat tires or need to check the pressure.
They went to Miller Tire in Dublin, Pa. - you may have to find a place
local ... or ship.
KK
Old July 5th 07, 02:32 AM posted to rec.aviation.soaring
COLIN LAMB
Tractor tires often have liquid weight added. The old medium was calcium.
It is very corrosive. A newer substance, just a little more money and much
less corrosive, is beet juice. Just put some in my tractor tire.
Colin
Old July 5th 07, 03:47 PM posted to rec.aviation.soaring
Z Goudie
Be aware that air filled tyres will flatten progressively
all the way to the wheel rim during heavy impacts and
consequently reduce the acceleration forces transmitted
to the structure.
Denser foam/liquid fills will deform at a slower rate
and/or deflect over a smaller distance thus producing
much higher dynamic loads.
Old July 6th 07, 03:25 AM posted to rec.aviation.soaring
Vaughn Simon
"Z Goudie" wrote in message
to the structure.
And a brass tailwheel?
Vaughn
Old July 6th 07, 04:59 AM posted to rec.aviation.soaring
On Jul 5, 6:25 pm, "Vaughn Simon"
to the structure.
Vaughn
Uh, say what? With the same rubber tire around the brass tail wheel as
around the standard plastic one you won't feel any difference beyond
the CG change.
Darryl
Old July 6th 07, 06:57 AM posted to rec.aviation.soaring
Z Goudie
And a brass tailwheel what??
Old July 6th 07, 05:18 PM posted to rec.aviation.soaring
P. Corbett
I suggest that before using a tail wheel which might increase the impact
loads in the tail, be sure to do the second part of the lower rudder
hinge A/D, if you haven't already.
Paul
Vega tail Wheel Max Kirschner Soaring 0 April 11th 05 10:51 AM
DG 505 tail wheel hub failure? Alfonso Ossorio Soaring 4 March 17th 05 07:30 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 02:34 PM
Tail Wheel Training Jim CRQ Owning 8 July 25th 03 07:04 AM
