a pickle of a carby problem....
Old July 21st 07, 04:27 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default a pickle of a carby problem....
new marvel schebler ma3 spav carby.
adjusted ok and runs the O-200 quite well.
idle ok and static peak rpm on the numbers.
leans out ok.
about 2 minutes after stopping the engine I get a dribble of raw fuel
out the venturi. I dont know how long this would occur because I turn
off the fuel. 100/130 leaded avgas is the fuel.
just pulled the little character off the aircraft and dismantled it.
checked for a leaking needle valve. no problems.
checked the float height, 7/32 on the nose.
blew air through the fuel line and moved the float to open and close
the needle valve. good positive fuel flow stoppage.
there are only 10 components in the entire carby, well thereabouts.
the problem should be caused by wrong float height or a bit of crap
stopping the needle valve from sealing ...but it doesnt appear to be.
is there any other problem that these carbys can have to cause a fuel
dribble about 2 minutes after engine stop?
I have to ask because I havent been able to buy a manual anywhere
despite trying for a month or so.
anyone with a clue as to what it could be?
the carby is zero time almost.
Stealth Pilot
Old July 21st 07, 04:51 PM posted to rec.aviation.homebuilt
On Sat, 21 Jul 2007 23:27:53 +0800, Stealth Pilot
The Marvelous Schebler is now sold by Precision Airmotive as the MSA Carburetor:
http://www.precisionairmotive.com/msasupport.htm
The page includes a link to the carb setup handbook, service bulletins, and
information on ordering the full carb manual.
Old July 22nd 07, 02:33 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sat, 21 Jul 2007 08:51:00 -0700, Ron Wanttaja
I think that they are the guys who ignored my purchase order.
never mind though I have it sorted.
"New carby syndrome" is the diagnosis.
there was some friable crud in between the needle and seat and the
fuel wasnt shutting off.
a few manual cyclings of the float with air into the fuel line and the
crud crushed and vanished. just hope it is all gone and I havent
missed any.
The marvelous schebler really is a neat piece of kit.
Stealth Pilot
Bomb in a pickle barrel from 10,000 feet ArtKramr Military Aviation 15 September 3rd 04 05:51 PM
ADF Problem tony roberts Instrument Flight Rules 14 May 12th 04 02:59 AM
do I have an ADF problem ? Dave Jacobowitz Instrument Flight Rules 6 April 1st 04 12:58 AM
KY 97A problem Continental Bill Piloting 0 October 18th 03 08:20 PM
EGT Problem Dennis O'Connor Owning 4 August 27th 03 04:25 PM
