What should the flap postions be while taking off?
Old September 10th 03, 01:05 AM
Shi Jin
Default What should the flap postions be while taking off?
Thanks.
Then during take-off, do the aileron and the flap use the same angle?
On Thu, 09 Jan 2003 11:03:05 +0100, DAN wrote:
Shi Jin wrote:
I want to make sure I have the correct understanding the functions of the
flops on the wing and the elevators on the stabilizer.
The flops on the wing is used to change the plane's angle around the
longitudinal axis while the elevator controls the pitch angle.
Nope. The flaps are used to change the camber of the wing, hence the lift coeff.
The ailerons (also on the wing, just farther out) control roll.
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 11:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 07:01 AM
TAS vs. flap reflex angle ELIPPSE Home Built 3 January 13th 05 07:00 AM
FA: M18B Dromader Flap & Aileron BFC Aviation Marketplace 0 September 24th 04 05:29 PM
Flap design question Chris W Home Built 1 August 4th 03 03:50 PM
